Old 06-14-2007, 11:51 AM   #1
Pleasanton , California
Blowing 30amp Fuses
Has anyone experienced a problem with the optional generator transfer switch blowing the 30amp fuses in the invertor? Everytime I connect my generator to the plug that is governed by the transfer switch it blows a 30amp fuse, this is even after making sure the generator is delivering the proper voltage. When I connect to the regular shorepower plug I have no problems.
Scott
takeachance is offline   Reply With Quote
Old 06-14-2007, 12:22 PM   #2
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Smile Hi Scott
Check your polarity on the generator plug. Make sure the negative and the ground wire are not reversed with hot wire. The black schoud be 120 volts the white return and green the ground wire. By the way where is the breaker that blows ? Is it on the generator or the trailer?
Most problems are wireing reversed.
Regards Russell from Sunn Tucson Az.
RUSSELL is offline   Reply With Quote
Old 06-14-2007, 12:43 PM   #3
Hi Russell:
It is the inverter in the trailer, so if it was a polarity issue wouldn't it also be a problem when I use the regular power recepticle? It only happens with the recepticle associated with the transfer switch.
Scott
Running Lights blowing fuses neil.ervin Electrical - Systems, Generators, Batteries & Solar 11 04-30-2006 07:37 PM
replacing glass fuses with blades maznblu Electrical - Systems, Generators, Batteries & Solar 4 08-05-2003 11:34 PM
A/C blowing the breaker Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-08-2003 10:52 AM
Furnaces blowing but no heat Dave Emmerich General Motorhome Topics 6 01-04-2003 07:53 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
