Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 11-15-2003, 08:10 PM   #1
westeagle
westeagle's Avatar
Profile:
Best Solar Panel recommendations please!
Hi
I'm wondering what brand of solar panel for recharging 12v battery is recommended by other members...
Any info would be appreciated.
westeagle is offline   Reply With Quote
Old 11-15-2003, 09:25 PM   #2
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
Kyocera, Shell (Siemens), and BP are all good brands.
At $474 plus shipping, the 120W Kyocera KC-120 gives about the lowest cost per watt, and 20-30AH/day IF you have a 56" long stretch of roof to mount it on.
The 110W Shell SM-110 is a little more costly at $535, gives only a little less, but is only 52" long.
BP's 120W SX-120 is over 57" and a bit more expensive yet.
You'll also need to buy mounts, cabling, and a charge controller. RV Power Products' Solor Boost 2000E MPPT controller is popular and about $206.
Northern Arizona Wind & Sun
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
RoadKingMoe is online now   Reply With Quote
Old 11-16-2003, 11:31 AM   #3
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Welcome to the campfire westeagle!
Palm Desert seems to suggest plenty of solar power. These forums have spent a lot of time on the potential and the limits of solar installations. I looked under the Search function for you and that was a mixed bag.
Take a look at the following threads and the contained crosslinks to other threads:
Boondocker Solar Package?
moneypit...the saga continues
Portable Generator
Reply back if you have further questions. Good luck on your search.
Solar Panel Mounting JaceBeck 1999 Safari 2 02-26-2003 03:55 PM
Generator or Solar? dmac Generators & Solar Power 9 02-17-2003 09:24 AM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
Solar Panel Installation 69Overlander Generators & Solar Power 23 11-19-2002 09:25 AM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 10:22 AM
