Old 06-15-2003, 10:05 PM   #1
Unhappy BBBBRRRRRRRLOW Serious voltage draw
Just finally got a generator hooked and when I throw on the breakers as soon as I plug in any wall socket it will throw both breakers and almost shut it down, I believe most major appliances to be off.IS THERE SOMETHING I AM MISSIG??? The gen. has 5000 wt.2400 cont. but it is old.. PO'ed in PA
Phaedrus is offline   Reply With Quote
Old 06-15-2003, 10:09 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
We have a gen at home and we had a similar issue. On ours, it turned out to be the carb. Worked great until you shoved a load on the motor. In our case connecting an appliance that took some load added demand to the engine that carb could not fill and as such, the engine died. Rebuilt the carb and the problem went away.
Basically, the carb could not get enough fuel to the engine when a demand was placed on it. One thing though, in our case the breakers did not throw.
Eric
Voltage Inverters mcostanzo Electrical - Systems, Generators, Batteries & Solar 12 08-01-2006 10:37 PM
Univolt Voltage Joe62984 Electrical - Systems, Generators, Batteries & Solar 5 03-01-2004 01:58 PM
Shorten Draw Bar? dmac Hitches, Couplers & Balls 10 10-23-2003 12:35 PM
Voltage Regulator Rayk Airstream Motorhome Forums 2 09-16-2003 06:36 PM
Alternator/ Voltage reg LKappenman Mechanics Corner - Engines, Transmission & More... 7 10-24-2002 10:24 AM
