Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 11-18-2008, 10:13 AM   #1
2016 30' Classic
Columbus , Ohio
Battery Disconnecting on Solar Application
I have the solar upgrade and new to this. My understanding is the solar panels are continuously charging my batteries. I want to store the batteries for the winter. Is there a preferred procedure to disconnect the batteries?
I suspect I should disconnect the negative first, then the positive leads; but because of the solar charging should I be taking precautions to somehow insulate the positive leads from touching the metal battery box and frame?
Like to know what others do.
2016 Classic
2016 Ford F-250 Lariat 6.7PSD
jeff4506 is offline   Reply With Quote
Old 11-18-2008, 03:43 PM   #2
"Cloudsplitter"
Not sure how the factory solar is wired, but shutting off the battery isolator switch should do the trick. See owners manual, the switch is located on the panel behind couch/bed slide-out drawer.
The battery boxes in our 03 Classic are made from a composite material but I still insulate the cables when removing the batts for the Winter. I occasionally plug into shore power with batts out so the insulation is more a precaution. I always go neg first, but remember you have two, so if you don't do both negs first, a short with one still connected will still cause a big surprise.
This is a useful item to keep 'em charged over the Winter...
BatteryMINDer Plus 12 Volt 1.3 Amp Battery Charger: BatteryMart.com
Old 11-18-2008, 04:34 PM   #3
2016 30' Classic
Columbus , Ohio
Thanks for the insight. I've read my manual thoroughly but I could have missed that. I recall reading the solar charging mechanism behind my couch (near the electric bus), but I thought it was enclosed and inaccessible. I'll have to take a look.
2016 Classic
Old 11-18-2008, 05:54 PM   #4
I approve of this message
ostream's Avatar
2006 28' International CCD
Redmond , Washington
+1 for the BatteryMINDer. With the factory solar upgrade, you should have 2 AGM batteries. If so, this is the correct maintainer - 12 Volt 1 Amp BatteryMINDer PLUS AGM
ostream is offline   Reply With Quote
Old 11-24-2008, 07:32 AM   #5
2016 30' Classic
Columbus , Ohio
Yes, I do. They're Lifeline GPL-24T. They're around 4 years old now. Not sure how the PO cared for them, but I suspect they probably sat in the box and kept maintained via the solar charging. Thinking they're probably on their way out, I brought them to Autozone yesterday to have a load placed on them. They thought they were still in good shape. Was wondering if others could share their experience with these batteries. They're crazy expensive and I was wondering what kind of life expectancy they have.
2016 Classic
Solar battery charging Charles Q Treichel Generators & Solar Power 24 02-22-2023 09:36 AM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 32 08-26-2019 01:23 PM
Which battery (batteries) are connected to solar? Santart Land Yacht/Legacy Motorhomes 1 08-29-2007 05:15 PM
Solar Battery Charger Cstar Generators & Solar Power 2 01-04-2005 11:59 AM
Disconnecting toilet from tank vishwa Airstream Motorhome Forums 1 09-06-2003 02:25 PM
