Old 10-15-2019, 10:34 AM   #1
1973 31' Sovereign
Cottage Grove , Minnesota
batteries and solar panels
I've been reading many articles on the addition of solar power to an airstream.
I am in the process of restoring my 73 31ft landyacht. i see many posts regarding output of solar power but very few incidents of placing multiple batteries under the r/v for power storage and boondocking. Is this primarily a weight and space concern?
gfmeyer is offline   Reply With Quote
Old 10-15-2019, 10:43 AM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Weight of lead acid batteries is most definitely a concern.
Many owners who focused on boondocking and energy storage are moving to lithium batteries. These are much lighter, store more usable energy per pound, last longer and have (subjectively) better operating characteristics. This comes at increased cost however.
wulfraat is offline   Reply With Quote
Old 10-15-2019, 11:01 AM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Well, a number of us have done both
I have four batteries and four solar panels. The batteries happen to be lithium's, but that's a different subject. Indeed people do go well beyond 4 batteries. In my case, that is all that would fit in "dead space" on the trailer. If I had more room, I'd put in more batteries.
Weight wise, lithium's do help a bit ( = they are lighter). On a "large" trailer, even 4 or 6 lead acid's aren't likely to overload your axles. Depending on where they go, they could have an impact on weight distribution in the trailer.
The advantage of solar is that it's quiet and it's "free". The disadvantage is that it pretty much dies when the sun goes down (no matter how many panels you have). Batteries are always there, but they have only so much capacity.
The "holy grail" for many people is running the A/C off grid. Doing that for an extended length of time ( = hours of run time) is going to be exciting without a generator involved. If that is not part of the deal then one can come up with a practical battery / solar combo that will work off-grid at least as long as your water tanks hold out.
Some math (based on a lot of guesses) :
Battery:
1) RV pulls 50AH a day ( 24 AH for fridge and 24 AH for everything else)
2) In 10 days you have run through 500AH
3) With lead acid's run to 50% that's 1000AH of battery
4) At ~ 100AH per battery you have 10 batteries
Solar:
1) Same 50AH per day
2) 400W ( = 4 panels ) on the roof
3) Typical day in a shady location provides 500 to 1,000 WH ( = 38 to 76 AH)
4) 200 AH usable batteries (so 4 lead acid's)
5) You can easily run for 10 days and likely much longer
If you buy fancy batteries at the prices some people seem to pay, ten AGM batteries will cost you quite a bit. In some cases lithium's actually would be cheaper than what some people spend. If you go with something like Trojan T-105's (which *are* good batteries) you should not be paying "near lithium" sort of prices.
One side benefit of solar is that it can / may be used to keep the batteries charged when in storage. That assumes you store outdoors and are ok with leaving the solar running. I see no problem with the "leave it running" part. Storing outdoors is not the way we do it.
Lots of options, lots of choices. As with just about everything in life, you decide what you can afford to do and go with that.
uncle_bob is online now   Reply With Quote
Old 10-17-2019, 11:52 AM   #4
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Hi
Battery:
Solar:
Excellent comment!
2018 Globetrotter 27Q, 29 nights 4,435 miles, 600W Solar, PD4655L, Duracell EGC2 Batteries, ProPride, 16" Michelin's, Champion 3400W Dual-Fuel, 2019 F250
Sold: 2017 Flying Cloud 25FB, 316 nights 40,150 miles, 400W Solar
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is online now   Reply With Quote
Old 10-17-2019, 05:17 PM   #5
1973 31' Sovereign
thanks Bob,
super helpful. I've got lithium ions in my boat. I don't know that we will r/v enough to justify the 900.00 individual battery cost.
For me the weight is not a factor. I'll post some pics when I get that far. My frame has some serious corrosion issues. Once i reconstruct the frame, my plan is to outfit it with some 6500lb torque flex axles and build an undercarriage battery box on slides mounted in front of the axles.
Old 10-18-2019, 09:26 AM   #6
Half a Rivet Short
Hi
The axles are one of many components that all add up to give you a "max weight" number. There are some pretty good design programs out there ($$$$) that will let you work it all out.
Startup Voltage for Solar Charger and 12v solar panels ggreen63304 Generators & Solar Power 12 09-01-2017 07:58 PM
Should solar panels and system go directly to batteries? GPafundi Electrical - Systems, Generators, Batteries & Solar 8 12-02-2016 11:54 AM
Solar Panels - how well do they work charging trailer batteries PSU1981 Electrical - Systems, Generators, Batteries & Solar 15 12-20-2015 07:17 PM
Solar Panels Charging Batteries while in storage Chuck Barber Generators & Solar Power 10 07-21-2015 10:37 AM
Solar panels, controllers, batteries... truckirwin Electrical - Systems, Generators, Batteries & Solar 7 05-12-2014 05:18 PM
