Old 08-11-2013, 06:02 AM   #1
Madman's Avatar
Decatur , Georgia
B VAN 190. 1998. Generator
How do I change the oil, oil filter and the spark plug? How do I slide the generator out so I can change the spark plug?
Madman is offline   Reply With Quote
Old 08-11-2013, 06:28 AM   #2
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Unless there is a hole underneath for access to the oil drain (some have this), you have to unbolt it and remove it from the enclosure. Careful, it weighs 113 pounds...
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 08-12-2013, 08:23 PM   #3
Madman's Avatar
Decatur , Georgia
I just wanted to give it a simple tune up, thank you for your answer.
M
Old 08-13-2013, 08:00 AM   #4
Skater's Avatar
1995 30' Excella
Bowie , Maryland
No problem. I would change the spark plug in mine, but for a full oil drain and refill it was next to impossible. I tried using a turkey baster to get the oil out, and it didn't work. Something like this might work, though.
If you do remove the generator, though, get a hole saw and put a hole in where the oil drain is so that you can do it easily next time. I should have had the shop do that when they installed my replacement generator, but I just didn't think of it.
