I've never seen one in person but they are shown as being an option in my 74's owner's manual. They called them battery chargers. Looks like the one in your pic has seen better days. They were probably a high maintenance item, you can do pretty much the same thing today with solar power.
Neighbor down the street has an Excella 500 with an Onan in it. I have not seen it but MarilynW has. He gave her the $.05 tour, opened the panel and showed her the Onan. She says it looked to be in good shape.
-BobbyW
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
I would be interested to hear how quiet it is. I would think it would be fairly quiet, considering it is in a housing. Really should not be to hard to get running, as long as you got propane, and spark, it should fly.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
That 12 volt generator was an option in 1973, on the larger models.
When it worked, it was great. Problem with it was altitude. If you adjusted it for sea level and went to 2000 feet, it would not start. If you readjusted it to the 2000 foot elevation, it would run OK.
When you returned to sea level, it again would not start, until you once again readjusted it.
That seemed to be an inherent problem. Therefore Airstream stopped installing it.
For those that may still have that generator, it appears that repair parts are long gone.
Was a great idea for those that liked to be self contained. It was quiet, efficient, and did a good job. Unfortunately, you had to be a generator mechanic to keep it adjusted correctly, at different elevations.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Neighbors Onan Generator on his 1974 Excella 500. MariilynW went and took some pictures of it. She said he has fired it up and then did so for her to show her how quiet it was. She said you cannot even hear it inside. Only a slight vibration when you are close to it.
-BobbyW
-BobbyW AIR# 123
-Red Green
that's cool bobby, thanks for the pic! now at least we know there are at least two still in existance!
my friends manuals are on order, when they arrive perhaps we will get a better understanding of the unit.
the timer in the living room has a max run time of something like 4 hours. i wonder if that is all that is needed to recharge a flat battery. or was it designed to be used under high load conditions, like running the furnace overnight to augment the battery.
Anyone worried about CO entering the cabin at all. I am sure new it was pretty well sealed, but as age sets in, are you all sure that it's still pretty sealed off from letting that nasty stuff back into the trailer?
