Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 07-17-2008, 09:39 PM   #29
wannabefulltime'n
wannabefulltime'n's Avatar
Profile:  1974 31' Excella 500
Weirton , West Virginia
How much would a working unit in good condition be worth to an interested Airstream restorer?
wannabefulltime'n is offline   Reply With Quote
Old 07-18-2008, 03:38 AM   #30
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
The 12 volt generator, was ok, sort of.
It has a huge problem, with the air/fuel mixture.
You can adjust it to work ok, at any given altitude.
But, when you changed altitude by as little as 1000 feet, the generator would not start/run correctly, unless you readjusted the air/fuel mixture again, and again.
That got old for me quickly.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 07-18-2008, 09:54 AM   #31
ronsgto
Profile:  1974 27' Overlander
Placerville , California
Well, thanks for the responces. If anyone has any skill on these I would appreciate the info. I know it's not worth putting much into but I would like to look into it anyway. The guy I bought it from said he hardly ever used it. It won't start and I have little knowledge on propane engines. If and when the budget ever changes I might look into putting a more modern generator in if it will fit.
ronsgto is offline   Reply With Quote
Old 07-18-2008, 10:05 AM   #32
richinny
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
just go to a rally and say, "i bet nobody can fix this!"
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 07-18-2008, 11:48 AM   #33
till
till's Avatar
Profile:  1967 26' Overlander
1968 26' Overlander
Lisle , Illinois
Images: 108
That engine sure looks a lot like a Briggs & Stratton. I bet parts are still available for it from B&S. You would be surprised at the parts they still make for them old engines. The thing looks like it would fit in a opening for a water heater.....
Tedd Ill
AIR#3788, WBCCI#4028 Membership discontinued
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 07-20-2008, 09:14 AM   #34
wannabefulltime'n
The engine is a vertical shaft Tecumsa (2.5 HP I believe) as found on many small lawn-mowers. A Propane engine is the same as a Gasoline engine except for the carb system. You can do a Google search and find many Propane conversion kits for anything from your lawn-mower to your TV.
I have one of these 12V generators from my '74 Excella 500 that I no longer want. It runs fine at my "Altitude" it may require adjustments at others, I don't know, I have never used it except for trying it out in my driveway before upgrading my AS. If anyone is looking for one to restore their unit to original equipment, make a reasonable offer plus shipping, I have no idea what it is worth.
