Old 03-17-2003, 01:41 PM   #1
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Question anyone ever seen a generator like this?
hi all,
anyone ever seen a onan generator like this? it has a control panel in the living room.
the name plate sez: 0.3 TL-212R
it is 12volt 20A 300watt
kinda looks like a lawn mower engine, electric start with a pull handle on the top.
it is a single cyl. horizontal engine. propane powered.
it is factory installed in a '74 excella 500.
any info or experiance with this type of unit would be appreciated!
john
Old 03-17-2003, 02:08 PM   #2
Chas's Avatar
Images: 22
I've never seen one in person but they are shown as being an option in my 74's owner's manual. They called them battery chargers. Looks like the one in your pic has seen better days. They were probably a high maintenance item, you can do pretty much the same thing today with solar power.
Chas
Chas is offline   Reply With Quote
Old 03-17-2003, 02:59 PM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
it turns over!
chas
it does turn over, and the electric start works too!
even though solar would be nice, thats not the point!
should be interesting to see if it can be made to run. what the heck, if nothing else the cool factor is way up there!
john
Old 03-17-2003, 03:10 PM   #4
Chas's Avatar
Images: 22
John,
Who's A/S is it on?
Chas
Old 03-17-2003, 03:15 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Talking a buddy
chas
it is on a friend's trailer, just brought it back from iowa this past weekend.
since i took the photo's i put them up fer all of you to see!
john
Old 03-17-2003, 04:15 PM   #6
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Neighbor down the street has an Excella 500 with an Onan in it. I have not seen it but MarilynW has. He gave her the $.05 tour, opened the panel and showed her the Onan. She says it looked to be in good shape.
-BobbyW
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 03-17-2003, 06:27 PM   #7
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
That is pretty cool.....
I would be interested to hear how quiet it is. I would think it would be fairly quiet, considering it is in a housing. Really should not be to hard to get running, as long as you got propane, and spark, it should fly.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 03-18-2003, 08:45 AM   #8
John.
That 12 volt generator was an option in 1973, on the larger models.
When it worked, it was great. Problem with it was altitude. If you adjusted it for sea level and went to 2000 feet, it would not start. If you readjusted it to the 2000 foot elevation, it would run OK.
When you returned to sea level, it again would not start, until you once again readjusted it.
That seemed to be an inherent problem. Therefore Airstream stopped installing it.
For those that may still have that generator, it appears that repair parts are long gone.
Was a great idea for those that liked to be self contained. It was quiet, efficient, and did a good job. Unfortunately, you had to be a generator mechanic to keep it adjusted correctly, at different elevations.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Old 03-18-2003, 12:48 PM   #9
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
What a dinosaur. I am comparing this to the Honda I just recently discovered on this forum. Amazing what about 30 years does.
30 years from now, maybe solar will be far more potent as well.
Eric
Old 03-19-2003, 05:13 AM   #10
BobbyW's Avatar
Houston , Texas
Neighbors Onan Generator on his 1974 Excella 500. MariilynW went and took some pictures of it. She said he has fired it up and then did so for her to show her how quiet it was. She said you cannot even hear it inside. Only a slight vibration when you are close to it.
-BobbyW
BobbyW
AIR# 123
Old 03-19-2003, 06:01 PM   #11
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Thumbs up thanks bobby!
that's cool bobby, thanks for the pic! now at least we know there are at least two still in existance!
my friends manuals are on order, when they arrive perhaps we will get a better understanding of the unit.
the timer in the living room has a max run time of something like 4 hours. i wonder if that is all that is needed to recharge a flat battery. or was it designed to be used under high load conditions, like running the furnace overnight to augment the battery.
john
Old 03-19-2003, 06:12 PM   #12
LOST , Hawaii
Maybe to conserve propane for the frig and furnace.
John
74Argosy24MH is offline   Reply With Quote
Old 03-20-2003, 05:21 PM   #13
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
good point!
good point john!
john
Old 03-20-2003, 06:13 PM   #14
Aluminut
2004 25' Safari
. , Illinois
Anyone worried about CO entering the cabin at all. I am sure new it was pretty well sealed, but as age sets in, are you all sure that it's still pretty sealed off from letting that nasty stuff back into the trailer?
Eric
