Old 07-17-2008, 08:39 PM   #29
wannabefulltime'n's Avatar
Weirton , West Virginia
How much would a working unit in good condition be worth to an interested Airstream restorer?
wannabefulltime'n is offline   Reply With Quote
Old 07-18-2008, 02:38 AM   #30
The 12 volt generator, was ok, sort of.
It has a huge problem, with the air/fuel mixture.
You can adjust it to work ok, at any given altitude.
But, when you changed altitude by as little as 1000 feet, the generator would not start/run correctly, unless you readjusted the air/fuel mixture again, and again.
That got old for me quickly.
Old 07-18-2008, 08:54 AM   #31
1974 27' Overlander
Placerville , California
Well, thanks for the responces. If anyone has any skill on these I would appreciate the info. I know it's not worth putting much into but I would like to look into it anyway. The guy I bought it from said he hardly ever used it. It won't start and I have little knowledge on propane engines. If and when the budget ever changes I might look into putting a more modern generator in if it will fit.
ronsgto is offline   Reply With Quote
Old 07-18-2008, 09:05 AM   #32
richinny's Avatar
2011 34' Classic
just go to a rally and say, "i bet nobody can fix this!"
Ricky
Old 07-18-2008, 10:48 AM   #33
till's Avatar
Lisle , Illinois
Images: 108
That engine sure looks a lot like a Briggs & Stratton. I bet parts are still available for it from B&S. You would be surprised at the parts they still make for them old engines. The thing looks like it would fit in a opening for a water heater.....
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 07-20-2008, 08:14 AM   #34
The engine is a vertical shaft Tecumsa (2.5 HP I believe) as found on many small lawn-mowers. A Propane engine is the same as a Gasoline engine except for the carb system. You can do a Google search and find many Propane conversion kits for anything from your lawn-mower to your TV.
I have one of these 12V generators from my '74 Excella 500 that I no longer want. It runs fine at my "Altitude" it may require adjustments at others, I don't know, I have never used it except for trying it out in my driveway before upgrading my AS. If anyone is looking for one to restore their unit to original equipment, make a reasonable offer plus shipping, I have no idea what it is worth.
Old 08-05-2012, 02:18 PM   #35
1964 24' Tradewind
Wausau , Wisconsin
I have the same generator in Stella (1974 31 ft. Excella 500). I don't think I want to deal with potential problems down the road so I am thinking or pulling it out. Question is: Will a trickle charger on the 12 volt work or can I take out the 12 volt all together??? Its really to bad the previous owner didn't take better care of Stella. I am finding tons of stuff that could have been avoided with some minor upkeep. I did however find a 1974 penny stuck under one of the tack strips when I pulled out the carpet. Kind of cool I thought.
Sharkey is offline   Reply With Quote
Old 08-05-2012, 04:46 PM   #36
2007 25' Safari FB SE
Suburbia , Sunny So Cal
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
