Old 08-05-2008, 01:25 PM   #1
1976 Argosy 24
Santa Clarita , California
Question Anybody tried the "DURATION POWER - EXTENDED RUN DURATION TANKS"?
Has anybody tried using the "Extended Run Fuel Tank - Single Feed" (for one portable generator) or the "Extended Run Fuel Tank - Double Feed" (for two paralleled portable generators) made by "Duration Power"? If so, what are your thoughts on them?
AndyPenny is offline   Reply With Quote
Old 08-05-2008, 02:48 PM   #2
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
I use the double feed. Works great. The two Honda 2000iu generators siphon right off the tank. Refueling is infrequent.
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 08-05-2008, 04:11 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I also have the double feed for two Honda 2000i's. Works like a charm.
Brian
SuEllyn & Brian McCabe
Old 08-05-2008, 11:26 PM   #4
1976 Argosy 24
Can you use the double feed version with a single generator when not running the A/C and therefore not needing to run both generators?
Old 08-06-2008, 05:44 AM   #5
Cyclist
henw's Avatar
Yes. The system is air tight to the duration tank.
2007 28' Int CCD.
Two big screens
Centramatics.
Old 08-29-2008, 12:56 PM   #6
2010 27' FB Classic
N/A , Texas
Where do you carry the extra tank? Does the (double) extra duration tank fit behind the propane tanks on the A frame of the trailer?
Power problem indicated by "weak" microwave? davida Batteries, Univolts, Converters & Inverters 4 06-12-2007 01:23 PM
Power steering problem on my "NEW" 345 JBK Mechanics Corner - Engines, Transmission & More... 19 10-23-2006 08:54 AM
Power converter "fuse" rfield54 1997 - 2004 Bambi 0 09-02-2003 02:26 PM
Water pump pressure duration? Mr. Bliss Water Heaters, Filters & Pumps 11 04-21-2003 10:31 PM
