Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 09-13-2009, 03:46 PM   #1
Profile:  2000 31' Excella
Maryville , Tennessee
Any difference ?
Had a Mallard sprinter, getting an Airstream.
Ran Honda 2000 generators with the Mallard with no problems or issues.
Will there be anything different on the Airstream I need to know when using generators or is it all the same deal.
Robbie R.
Robbie R. is offline   Reply With Quote
Old 09-13-2009, 04:29 PM   #2
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
Pretty much the same type of restrictions between the two unit.
As you know
certain things are a no no, like microwave running at the same time as the A/C etc..
Of course, you can read the thread on that subject too..
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 09-13-2009, 05:15 PM   #3
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
Should be the same...
Was the Mallard 30 amp? Your AS will likely be 30 amp, so make sure you have the correct plug coverters, etc. for the generator(s)...if you need them. Our Honda 2000 Campanion has a 30 amp plug-in but it is a twist & lock 30 amp plug-in, so we have to use a converter with it to receive a regular 30 amp RV plug.
TB & Greg...and Cockers Annie & Sadie
AirForums #21900 . WBCCI F
our Corners Unit #3954
Décor Site: AZBambi Décors
Old 09-13-2009, 10:07 PM   #4
Thanks guys, that is what I needed to know. My other was a 30 amp and I now have 2 Hondas 2000s companions so I should be good to go.
I just wanted to make sure AS did not have some sort of lock out or electrical deal that made a generator hard to use unless you did certain things etc.
Should be just like the other campers then.
Robbie R.
Old 09-14-2009, 06:42 AM   #5
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Everything should be pretty much the same. I use a pair of Hinda 2000's with the older parallel add-on unit. Mine has the 30 amp RV outlet that the Airstream plugs into without any adapter.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Difference in 30 and 31 ? Robbie R. 1998 Excella 1000 3 09-04-2009 06:22 PM
What's the difference? Hoosierdaddy General Repair Forum 9 10-28-2008 06:56 AM
Anybody know the difference... Minnie's Mate Off Topic Forum 10 08-31-2008 10:46 PM
What a difference gowyn Tow Vehicles 11 10-17-2007 07:10 AM
the difference... bradk Towing, Tow Vehicles & Hitches 11 05-22-2006 09:27 AM
