Old 10-25-2007, 01:05 PM   #1
westernviews's Avatar
2013 27' Flying Cloud
Livingston , Texas
Another generator question
Can you keep a generator in your truck and use it while it is in the truck, without putting it on the ground (as long as it is well ventilated)? I really like the electric start Yamaha generator, but there is no way I can lift 150 lbs in and out of my truck by myself. Even with a ramp it would be difficult. So, does anyone out there keep their generator in their truck permanently?
Westernviews.us
westernviews is offline   Reply With Quote
Old 10-25-2007, 01:09 PM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Yes you can, I am leaning that direction with my 2400is. Partly because I don't want to lug the bugger and partly because I will feel better if it is bolted into my bed. This option is less useful if you plan on using the generator for much more than battery recharges. If you will be running the thing for extended periods, or want electricity when the TV is somewhere else, then this plan isn't so hot.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 10-25-2007, 01:14 PM   #3
2005 31' Classic
Gretna , Nebraska
A fellow in our unit has his Honda 3000 in his truck bed and runs it there.
Dwight
16595 is offline   Reply With Quote
Old 10-25-2007, 01:21 PM   #4
TIMEMACHINE's Avatar
Huntington Beach , California
yep..
Sure can, I do it with my Yamaha 3000 w/boost. I have it chained down and also have two HD cable locks attacched to the frame of the gen. It actually reduces the noise even more ( not as though it isn't already super quiet) being surrounded by the bed and cab.
We have traveled over 20,000 miles, sea to sea, and no one has ever messed with the generator in the bed. Keep it covered when not in use, something other that a generator cover is best to decrease the awareness of the bad guys, like a cheapo BBQ cover, it works for us.
time
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
TIMEMACHINE is offline   Reply With Quote
Old 10-25-2007, 01:57 PM   #5
Livingston , Texas
Smile
Thanks so much for the info. The Yamaha 3000 w/boost is just what I wanted to get.
Westernviews.us
Old 10-25-2007, 08:15 PM   #6
johntavares1's Avatar
2007 25' Classic
1999 35' Cutter Diesel Bus w/slide
Fall River , Massachusetts
Question gen. or solar
If you had to choose would you get a generator or go solar?
John
johntavares1 is offline   Reply With Quote
Old 10-25-2007, 08:34 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
John
John,
It depends on what your usage will be. A generator of the proper size will power everything in your trailer including the A/C. Or a smaller gen can be used for battery charging and small electric appliances (2000 watt). They can be converted to propane or you can order the Yamahas that way from the factory with a warranty and use your LP tanks.
OTOH, solar is silent and a one-time investment. It will also keep your batteries up and with an inverter, you can still power some small appliances or TV. Only down side to solar......you don't get nuttin' at night!!!
Old 10-26-2007, 12:24 PM   #8
2007 25' Classic
Thanks for the reply but which would you choose if you had to choose one?
John
Old 10-26-2007, 02:28 PM   #9
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
John
Generator every time. I like the idea of solar, but it has to many drawbacks- not the least of which is I like to camp in the shade. Furhtermore, it cost less to get going and you have to burn a lot of gas before the "free" sun will catch up with the cost of fuel.
Rodney
and the
My Blog
Old 10-26-2007, 03:57 PM   #10
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Yes you can. I do it with my bulldog 3500. . In addition, I put hard foam panels agenst the bed sides of the truck. The foam panels help reduce the noise somewhat As stated, just keep it ventilated.
Safari-Rick
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Generator Question ScrapIrony-2 Generators & Solar Power 12 01-13-2005 03:55 PM
Generator Question? ssolid 1970-79 Tradewind 3 11-06-2004 04:48 AM
Generator question Princess Generators & Solar Power 14 03-03-2004 10:14 PM
another Generator question George Airstream Motorhome Forums 3 08-14-2003 05:17 AM
Generator question Melvin P. Thorpe Generators & Solar Power 10 04-11-2003 07:39 AM
