Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 05-26-2007, 07:57 AM   #1
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
AM Solar SunRunner 100/H22B Install
With the help of one of my sons (cost me a Super Supreme pizza), I installed two of AM Solar's 100 watt panels to my roof yesterday evening. The sun came up about 11 o'clock in relation to the streetside of my trailer and I was pleasently surprised that the Winegard antenna (down) and rear Fantastic Vent fan cover did not project a shadow onto either panel. The panels were mounted with rocker type feet and 3M tape then covered with Trempro 635 caulk.
ID:	37931  Click image for larger version
ID:	37933  Click image for larger version
ID:	37935  Click image for larger version
ID:	37937  Click image for larger version
ID:	37939  Click image for larger version
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-26-2007, 08:01 AM   #2
davidz71
davidz71's Avatar
Two more
Couple more pics showing rocker foot mount. I also ordered two sets of tilt bars for cleaning up uner the panels or tilting the panels during winter months.
ID:	37941  Click image for larger version
Craig
AIR #0078
3.73 rear end
Old 05-26-2007, 08:05 AM   #3
davidz71
davidz71's Avatar
The shadows you see on the cardboard are from the sun around 6 p.m. in the evening when it was very low. That was to be expected. This morning's sun at 8 a.m. CST did not do this.
Craig
AIR #0078
3.73 rear end
Old 05-26-2007, 11:35 AM   #4
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
think the tape will hold?
or are you going belt and suspenders and rivet them in place?
john
you call them ferrets, i call them weasels.
Old 05-26-2007, 11:49 AM   #5
davidz71
davidz71's Avatar
AM Solar said they have not lost a panel yet IF the tape was put on in over 50 degree temps. It was in the 80's yesterday evening. I plan on running a safety wire near my antenna just to be on the safe side.
Craig
AIR #0078
3.73 rear end
Old 06-03-2007, 12:47 PM   #6
davidz71
davidz71's Avatar
Finished
A few last pictures of the SunRunner system. It is working great. Next year I will add two smaller panels (65-70 watt) on the front.
ID:	38509  Click image for larger version
ID:	38511  Click image for larger version
ID:	38513  Click image for larger version
Craig
AIR #0078
3.73 rear end
Old 06-03-2007, 01:11 PM   #7
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Hi davidz71
Are you planning to use them just as a charging system or are you going to install an invertor and use any 110 equipement?
Are they just held on with double sided tape? The hatches on my kayak are magnetic but I still use a strap over them when on the road.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 06-03-2007, 01:38 PM   #8
pmclemore
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
Craig,
Your posts here are giving me confidence to try this myself. Great job log and pix. I presume you are satisfied with AMSolar's materials and instructions?
Your rocker feet - are they on all four corners so you can tilt east or west?
Thanks and congrats - Pat
pmclemore is offline   Reply With Quote
Old 06-03-2007, 03:37 PM   #9
audiobox
newbie
audiobox's Avatar
Profile:  1970 21' Globetrotter
1987 34' Excella
Portland , Oregon
Good one!
Nice installation and photos Craig! When I interviewed Greg and asked him what the number one problem was for DIY RV solar installations, he told me it was failure due to wire chafing. It looks like you've done a good job with the wire hold-downs to prevent this. I think you did well in labor negotiations too!
Craig
http://www.shinytrailer.com
audiobox is offline   Reply With Quote
Old 06-03-2007, 05:42 PM   #10
davidz71
davidz71's Avatar
Originally Posted by HowieE
Hi davidz71
Howie,
AM Solar claims that the 3M tape will hold better than rivets. I've thought about a safety cable/wire of some type to be on the safe side but don't know what I will do at this point.
I have a Coleman 800 watt inverter that I am thinking of mounting in the space under the streetside couch arm. I am also going to two 6 v. batteries in the near future which will be mounted in a new box constructed between the frame rails where a storage box now resides.
Craig
AIR #0078
3.73 rear end
Old 06-03-2007, 05:54 PM   #11
davidz71
davidz71's Avatar
Originally Posted by pmclemore
Craig,
Pat,
The toughest job was planning what I was going to do next. The panels both mounted within a couple hours after moving them around to find just the right spot. Wiring took much of the time because I was thinking a step ahead as to placement of the charge controller.
Rocker feet were set up to raise the outside edges up to catch additional sun during the winter when the sun is lower in the sky. I've also though about drilling an extra hold in each tilt bar to level the panels when parked. I'm going to experiment to see if that makes a difference in the output.
I'm happly with the material sent by AM Solar. Instructions were included in many of the packets and the wiring harness was top notch. The HPV-22B controller was a nice touch. I'll probably place a clear plastic cover over the controller to keep dust down but want to make sure that there is air at the bottom of the cover to allow air to move around the panel as mentioned in the directions.
Craig
AIR #0078
3.73 rear end
Old 06-03-2007, 05:59 PM   #12
davidz71
davidz71's Avatar
Craig
Craig,
Thanks. I also added wire loom over the 8/2 cable where it ran over the refrigerator fins and near the refrigerator coils. I was concerned about heat as well as chafing. I am going to caulk the hole where the cable entered the credenza tonight and that will do it.
Craig
AIR #0078
3.73 rear end
Old 06-03-2007, 06:14 PM   #13
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
I was looking at these panels they are about $1500 and adds about 50 pounds to the roof, to say nothing of wind resistance.
Why not get four 6 volt batteries?
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 06-03-2007, 09:33 PM   #14
audiobox
newbie
audiobox's Avatar
1987 34' Excella
Portland , Oregon
Originally Posted by davidz71
Craig,
Good plan. The AMSolar guys loom almost all of their "on the wall" cable runs. I know you'll enjoy having your system ticking away for you this year.
Craig
Help... I Need To Install A Gray Water Tank???? kangol Waste Systems, Tanks & Totes
