Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 05-15-2007, 02:01 PM   #1
ESCAPE POD
ESCAPE POD's Avatar
Profile:  2007 19' Safari SE
Seal Beach , California
Question Altitude generator adjustment
I have a Honda 2000 gas generator, and will be operating it at 8K ft. Does anyone know how to adjust the carburetor for high-altitude use?
We shall not cease from exploration, and the end of all our exploring will be to arrive where we started and know the place for the first time. -T.S. Eliot
Jerry & Susan
2007 19' Bambi SE
2003 Dodge Dakota 4.7L V-8
ESCAPE POD is offline   Reply With Quote
Old 05-15-2007, 03:37 PM   #2
JK3500
Profile:  2005 22' International CCD
Woodland Park , Colorado
From what I understand the carbs on these generators come preset from the factory and are not adjustable at the user level (someone correct me if i am wrong). One of the advantages of the propane conversions is you have the ability to adjust the fuel mixture for optimal operation at altitude.
FWIW, my Yamaha 2400is generator straight from the factory worked just fine here at 8600' on gas. It did run a bit smoother on propane after the conversion with the fuel/air mixture dialed in. jk
JK3500 is offline   Reply With Quote
Old 05-15-2007, 03:42 PM   #3
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
I heard the same thing FWIW, but I cannot confirm this is so....I can however say the propane modified gens can be adjusted....or at least the one I got from US Carb (Yamaha 1000).
Old 05-15-2007, 04:18 PM   #4
silverback
silverback's Avatar
Profile:  2006 28' Safari SE
Phoenix , Arizona
I've used an EU2000 (petrol) at 9K feet and didn't know I might have problems until I saw that in the manual. You probably will have to use more choke to start it.
-KL
4CU Charter Member
2004 Silverado 2500 HD D/A
Honda EU2000i
Hensley Arrow
KE7DUI
silverback is offline   Reply With Quote
Old 06-10-2007, 10:10 AM   #5
DFord79
DFord79's Avatar
Profile:  Currently Looking...
Yakima , Washington
Don't worry about altitude. It will run fine I have been told by a local Honda dealer. Switching to propane does allow for adjustment but you also loose 10% efficentcy over gas (per my local dealer).
DFord79 is offline   Reply With Quote
Old 06-10-2007, 10:30 AM   #6
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
It may have compensation built in-some newer equipment does. The higher you go, the less oxygen(and the less power available). This means less fuel can be burned. As you go up, the mixture must be leaned out to maintain a 15:1 ratio. Symptoms of an over rich mixture are the same as reunning with the choke on.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-10-2007, 10:37 AM   #7
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
I have run my EU1000 at up to 9000 feet with no problems. It starts on the first pull almost every time.
Richard
Charter Member Four Corners Unit
Old 06-10-2007, 10:53 AM   #8
lsinclair
lsinclair's Avatar
Profile:  2008 30' Classic
Pagosa Springs , Colorado
I have two EU2000 and have had no issues starting or running. We live at 8K and have operated them at 10K elevation. Fuel consumption is very low at these elevations.
Safe and enjoyable travels,
Larry
lsinclair is offline   Reply With Quote
Old 06-10-2007, 09:57 PM   #9
Motoman
Motoman's Avatar
Profile:  2005 25' International CCD
1960 18' "Footer"
Riverside , California
If you were going to operate the generator at high altitude for almost all of its life you would want to modify the carberutor to lean out the mixture. Years ago the carburetor might have had an adjustible main jet but today you would disassemble the carburetor and replace the main jet, possibly the idle jet and othe parts in the fuel mixture circuit to lean out the mixture. You can buy the main jet and other parts at a Honda dealer ( see this web site as an example Plano Power Equipment Online Store - Honda EU2000i Generator Common Parts ). There are replacement jets for 4000-7000 ft, 6000-10,000 ft and 9000 to 15,000 ft.
You would not want to rejet the carburetor for occassional use at high altitude, only if its primary use was above 5000 ft and it would rarely be used below that elevation. Running an engine jetted for low elevation at 5000 ft and above would cause it to run slightly rich and not likely damage the engine. However, running an engine at lower elevations when it was jetted for operation above 5000 ft will cause it to run lean, possibly overheat and result in shorter valve life. I agree with the other responders, choose which condition best fits the majority of your use and then either leave the jetting stock or change it based upon your decision.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Generators . . . again? dinoburb Generators & Solar Power 6 03-18-2008 08:36 PM
2 Catastrophic Tire Failures in 1 Day !!!!!!! gklott On The Road... 59 11-25-2006 11:51 AM
Rocky Mountain "Forum Rally" Info InsideOut The Rally Zone 162 06-28-2003 04:56 PM
New Owner-tow vehicle discussions JodynJeep Our Community 28 10-15-2002 11:43 PM
