Old 05-03-2010, 07:24 AM   #1
asheville , North Carolina
Advice on 15 Watt solar battery charger
We have a new 15 watt portable battery charger. How reliable are battery chargers ...are there better, more efficient ways short of using a generator to recharge batteries if boondocking? We have two 12V batteries on our International.
rywnc is offline   Reply With Quote
Old 05-03-2010, 07:32 AM   #2
A 15 watt solar panel, at best, will keep the batteries "topped off".
The 2 batteries have a total available amps of about 200.
Your charger, at full sun, will charge at the rate of 1.25 amps, per hour.
Even at that, the charging rate is dictated by the position of the sun on the solar charger.
When the sun is at an angle to the charger, the charging rate decreases.
I would not depend on that charger to do anything more than keeping the batteries topped off, and then only when you are drawing "zero" current.
Old 05-03-2010, 08:09 AM   #3
Airstream25's Avatar
1995 25' Excella
1982 34' Limited
Albuquerque , New Mexico
Images: 21
Send a message via Skype™ to Airstream25
In my opinion, a solar panel is the best choice if boondocking.
However, I think you need way more than 15 watts,( I just took delivery of a 135 watt panel).
I also think that for max. convenience, the panel(s) should be mounted on the roof. That way, you don't have to handle them every time you want to move your Airstream.
With solar, you have zero ongoing expense, zero noise, zero pollution.
The down side is rainy/cloudy days and that fact that it will not run your microwave.
Airstream25
KE5CKG on 2 meters
AIR #10274
Airstream25 is offline   Reply With Quote
Solar Charger Airstream12557 Land Yacht/Legacy Motorhomes 5 04-07-2010 10:36 PM
Leaving an AGM battery in my Airstream over the winter (solar charger) wacnstac Batteries, Univolts, Converters & Inverters 0 05-25-2009 08:13 PM
Solar Battery Charger Cstar Generators & Solar Power 2 01-04-2005 11:59 AM
Solar Charger Sneakinup Generators & Solar Power 1 10-07-2003 09:04 AM
Solar trickle charger.... drboyd Generators & Solar Power 27 09-20-2003 07:51 PM
