Old 12-05-2019, 10:30 PM   #1
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
Advantages and disadvantages of hooking solar controller directly to the 12v bus bar
I've not seen this talked about.
What are the advantages and disadvantages of hooking your solar controller output directly to the RV Bus bar since it has a connection to the batteries already?
Is there a reason why one should not do so?
To me it seems redundant to run another set of wires to the batteries when the controller is mounted inside the trailer.
Some of the current could be used to run the 12 volt stuff in the trailer as the batteries are in absorption phase
Is there a need to use the batteries to filter the current coming from the controller?
Or if it should not be done at all, Why?
Thank you,
Matti
Mattirs is offline   Reply With Quote
Old 12-05-2019, 11:36 PM   #2
1971 27' Overlander
Kansas City , Kansas
It doesn't matter
Shermy1987 is offline   Reply With Quote
Old 12-06-2019, 12:30 AM   #3
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
Thatís what the Airstream does with the roof mounted panels.
daleyocum is offline   Reply With Quote
Old 12-06-2019, 12:36 AM   #4
2007 22' International CCD
My DIY solar system is correctly connected to the battery side of the use/store relay.
The idea of the solar controller and panels is not to power the trailer, itís there to charge batteries.
In fact, if my MPPT controller is not connected directly to the batteries itís output is zero.
rmkrum is online now   Reply With Quote
Old 12-06-2019, 08:01 AM   #5
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
My solar is connected to the busbars like diagrammed on page 8-17 of my Airstream's owners manual. Link: https://www.airstream.com/wp-content...manual-150.pdf The solar connections are the large (6GA) orange wire and the large black wire at the bottom of the picture. The copper connections are Blackburn 6GA copper lugs: https://www.lowes.com/pd/Blackburn-2...r-Lugs/4582297 This connection method works perfectly and provides an easy connection point when your batteries are mounted in the Airstream tongue-mounted battery box.
2018 Globetrotter 27Q, 32 nights 4,935 miles, 600W Solar, PD4655L, 6V Batteries, ProPride, 16" Michelin's, 2019 F250 PSD
Sold: 2017 Flying Cloud 25FB, 316 nights 40,150 miles, 400W Solar
Sold: 2013 Casita SD17 89 nights 16,200 miles
Solar Production: 213 kWh in 248 days of use
AirMiles is offline   Reply With Quote
Old 12-06-2019, 10:10 AM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Since solar is free, it sort of does not matter what you do. The "stock" approach is to route it to the DC bus bar. There is no practical downside to doing this as long as you have fuses in the right locations.
The only exception would be if your solar puts out something like a hundred amps. The battery hooks to the bus through a 50A breaker ... You physically can't put enough panels on a 25' to get that sort of current so it's a non-issue in this case.
Old 12-06-2019, 10:41 AM   #7
waninae39's Avatar
2017 22' Sport
NCR , Ontario
you need a solar controller.
the battery voltage is constant
the solar panel voltage varies (based on dynamic sun levels)
The solar controller matches the two so that it can convert the solar output into something that the battery can take as input
waninae39 is offline   Reply With Quote
Old 12-07-2019, 02:10 AM   #8
Mattirs's Avatar
Thank you everybody, I've read a lot of posts here and they never talked about tying the controller to anything except to the batteries snd I being funny like I sm wondered is there a reason why it should not tie into the bus bar.
Thank you airmiles for answer with what to use.
Thanks again,
Matti
12v
DC Bus Bar Box - Question - Loose bar free in box JennyJakeNH Electrical - Systems, Generators, Batteries & Solar 1 07-16-2019 06:37 PM
Advantages or disadvantages of an AS slide out carver 1 Airstream Lifestyle 21 12-08-2014 11:31 PM
Advantages and disadvantages CMSmith Our Community 10 02-06-2012 01:03 PM
Advantages / Disadvantages of Astrodomes Grand Master Roof Vents, Skylights & Fans 3 04-24-2009 07:53 AM
Advantages and disadvantages of 28 vs. 34 Scott Hopkin Airstream Trailer Forums 11 02-25-2005 11:32 AM
