05-12-2008, 09:56 PM
2007 25' Safari FB SE
Petaluma
Adding Solar Panels to a Safari 25' FB
I was wondering if any of you have added solar to a 2007 Safari SE 25' FB model that didn't come with solar? I'd like to maximize the output without having panels immediately visible on the upper radius of the trailer (preferring to keep things on the top portion) and not blocking the factory galley skylight.
If you have added solar to a similar trailer, what panels did you use and do you have any words of wisdom to share?
Thanks!
Aron
05-12-2008, 11:16 PM
2005 25' International CCD
1960 18' "Footer"
Riverside
We installed solar on our 25' CCD which has the same size roof although equipment locations may dictate a different size and panel layout. You can check out an article on our install on page 4 in the April Sierra Nevada Unit newsletter at :
http://sierranevadaairstreams.org/sn...snu-nwsltr.pdf
A longer description is found on their web pages at:
Solar Panel Installation
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
05-12-2008, 11:27 PM
Petaluma
Wow! That's really excellent detail, thank you, Don! Nice work too, maybe I should bring my trailer to you ;-). Thanks for sharing that.
Aron
05-13-2008, 12:10 AM
1960 22' Safari
in the wilderness
, The great Mojave Desert
We had a panel installed on the center of the roof between the A/C and the vent over the bed on our 25 FB.
Almost impossible to see from ground level.
Works great all around but really shines in winter when we run the furnace all night. Charges the batts up by noonish.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
05-13-2008, 12:14 AM
Petaluma
Goin camping, what size/brand panel did you go with?
05-13-2008, 12:24 AM
1960 22' Safari
in the wilderness
I don't remember.
But I can tell you what I do. Airstream offered three sizes of panel and I picked the middle one.
I bought the parts from and had the installation done at C&G in Bellflower. They are an authorized Airstream repair station.
Cost for parts and installation was $1,300.00
WBCCI 3344 FCU
AIR# 13896
CA 4
05-14-2008, 08:18 AM
1960 18' "Footer"
Riverside
Aron, one postscript to my install if you do it yourself. One person told me that they hit and damaged some of the wiring in the roof when they drilled for the panel mounts just above the drip rail on their trailer. The bit went in too deep. They had to cut a larger hole to expose the wires for repair and then install a patch. I would caution you to use a sharp drill bit so you don't have to use a lot of pressure and a depth gauge, some electrical tape or a ring that you clamp on to the drill bit so you don't drill any deeper than you need to to penetrate the aluminum skin and rib (if you install the mounts where the ribs are located).
Regarding dealer installation, we had Duane at Southwest Coaches in Irvine, CA install the 50 watt panel on our first Airstream, a 22' CCD. I looked at the same systems, capacities available and how they mounted and decided to do it myself because I wanted a higher capacity system than the dealers typically install.
SNU #157
FCU #004
05-14-2008, 02:40 PM
1986 25' Sovereign
Southern Middle
, Tennessee
OR rather than drilling, use the 3M Industrial tape after preparing the mating surface. The 3M tape provided on the rocker arm mounts through AM Solar have kept all 3 of my panels rock solid for over a year with no trouble. This would eliminate penetrating the skin with the potential for leaks later on.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
05-14-2008, 05:39 PM
Naples
Ya beat me to the punch!
I'm an AM Solar dealer/installer, and I use the 3M 'VHB' (very high bond) tape for every install that I can. It works especially well on bare meal like Airstreams. I used it initially on the system that I have on my Sprinter roof (a 200 watt, 2-panel system with a 2000 watt sine wave inverter and 300 amp/hour Lifelines), and it holds remarkably well!! The best part is that it can be removed without leaving a trace....very difficult, but do-able.
As davidz71 said....NO LEAKS!!!! and no extra sealant required. Just clean as specified (very important) and stick it down.
I have a nice big roll of the stuff if anyone needs some. Not cheap! But definitely worth it!!!!
lewster
05-14-2008, 06:16 PM
More than one rivet loose
Los Alamos
, New Mexico
Thanks!
Aron
I have two on top of my 31 Classic. you cannot see them from the ground. I want to add two more 85w class. There is room.
Michelle TAC MT-0
Sarah, Snowball
05-14-2008, 06:29 PM
Los Alamos
, New Mexico
You just solved a big road block! I did not want to drill any holes in the top of my trailer!
Michelle TAC MT-0
Sarah, Snowball
06-28-2008, 10:39 PM
Petaluma
Update
I ended up with the AM Solar AM-100-22 kit and it worked out great. I used the 3M tape to mount the brackets but just in case I mounted the front brackets above a rib so I can drill through should I get anxious about it but it sure looks like the tape is going to hold tight. I was able to fish the power cable through the refrigerator vent as recommended in the Airstream manual then I mounted the controller in the shallow cabinet above the fridge and connected to the prewire at the bottom of the fridge compartment accessible through the outside rear fridge panel. I had to join the yellow and green wires for the factory pre-wire kit to the existing battery bus under the front bed but it was really pretty simple--much more so than I expected.
I've not been out camping with it yet but on the late afternoon I checked the battery charging output I saw 5.4 charging amps which seems entirely reasonable considering I wasn't optimally positioned.
AM Solar was terrific to work with--they asked lots of questions to make sure I got the right parts, shipping was a reasonable $25, and the packaging of the parts was personalized and perfect.
Because of various roof vents I only have room for one panel between the AC and the bedroom vent. I could in theory extend the mounting brackets to rise above the vents to add another but I think I'll be fine with the one panel for now, I'll know more after a few trips and I always have the E2000 generator just in case.
Thanks everyone for your words of wisdom and experience, it was very helpful.
Aron
06-29-2008, 04:20 AM
2004 22' International CCD
Spotsylvania
, Virginia
To use the 3M VHB tape, do you need to remove any white paint on the roof to get the best possible bond?
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
06-29-2008, 09:13 AM
1978 Argosy Minuet 6.7 Metre
1977 31' Sovereign
1977 Argosy 24
Cincinnati
, Ohio
For anyone interested, I documented the installation of solar panels on my Argosy.
You can view it in the Airstream Projects section of my Web Site.
Dave
Visit my web site for Airstream Photos, Projects & Blog
06-29-2008, 10:06 AM
Naples
In my experience....NO!
The VHB tape does a great job of bonding the panels to any smooth, properly prepared surface. The white finish is sufficiently bonded to the bare aluminum at the mill by Alcoa so you don't need to remove any of the coating.
I mention 'properly prepared surface' because this is key to getting the tape to bond correctly. Clean as recommended at least 3 times to be sure that you have no dirt, contaminates, grease, oil, fingerprints, etc. on the bonding surface. You should be good to go after that!
lewster
05-28-2014, 09:05 AM
Boulder
Hi there,
We're going to go the 3M VHB tape route for a solar install - is there a specific type you use? When I search for it I see anything from "4941", "4942", "5952", 3M VHB tapes...
Thanks in advance for any advice!
Livin' the Dream
05-28-2014, 11:28 AM
2014 25' Flying Cloud
Cuddebackville
, New York
This thread is 6 years old. You might do better sending Lewster a PM.
2019 Ford Expedition Platinum
05-28-2014, 02:22 PM
Naples
WOW! How the past comes back at times. I use 4941.
lewster
05-28-2014, 07:52 PM
1987 25' Sovereign
Fort Collins
Has anyone claimed the Residental Energy Tax Credit for a solar installation? Instructions to Form 5695 seem to say this qualifies -- at least it does for houseboats and mobile homes. Just curious...
Alumacoot
“We are confronted with insurmountable opportunities.”
05-28-2014, 07:57 PM
Salem
, Oregon
Hi, I don't have solar on my trailer or my house, but to qualify for credits I have to have an electric bill of over $150.00 per month; We don't come anywhere near that.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
