Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 06-29-2008, 11:06 AM   #15
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Originally Posted by rseagle View Post
To use the 3M VHB tape, do you need to remove any white paint on the roof to get the best possible bond?
In my experience....NO!
The VHB tape does a great job of bonding the panels to any smooth, properly prepared surface. The white finish is sufficiently bonded to the bare aluminum at the mill by Alcoa so you don't need to remove any of the coating.
I mention 'properly prepared surface' because this is key to getting the tape to bond correctly. Clean as recommended at least 3 times to be sure that you have no dirt, contaminates, grease, oil, fingerprints, etc. on the bonding surface. You should be good to go after that!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
solar panels for my 22' flying cloud urbanfood Generators & Solar Power 11 11-07-2007 10:47 PM
Flexible Solar Panels joecolao Generators & Solar Power 9 03-07-2007 09:00 PM
Why Not Free Standing Solar Panels? bhunt Generators & Solar Power 18 02-05-2007 02:39 PM
Solar Panels or Generator? Ron C Generators & Solar Power 7 07-11-2005 12:19 PM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 08:47 AM
