Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 04-03-2008, 10:20 AM   #1
richschafer
Profile:  Lafayette , Rocky Mnt. Region
Adding a New Panel to the Factory Solar
I have a Safari 25' FB with the factory solar option. I was up on the roof last weekened and took some measurements to see if I could add another solar panel. It looks like I can fit a Kyocera KC85T between the AC and the front fantastic fan.
From what I have read on the forums and elsewhere, it seems like the wiring would be fairly easy: hook the new panel up in parallel with the existing panels. I know there is concern about hooking up different kinds of panels in series, but parallel should be ok.
However, I'm not sure how to mount the panel. It appears that people have used rivets, tape(?) and sheet metal screws. Does anyone know the relative benefits of each? This is our first AS, which makes me a little nervous about attaching things to it and I'd like to make sure I do it right.
If anyone has tried this, I'd really like to hear about your experiences.
richschafer is offline   Reply With Quote
Old 04-03-2008, 10:32 AM   #2
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Hi Rich -- It's for a different system than the factory probably, but davidz71 has posted about his installation. PM him to look in here and he may have some insight to your questions.
Solar panel position - pictures?
AM Solar SunRunner 100/H22B Install
Solar Panel Combiner Box
Factory Installed Solar Charging System SilverGate Generators & Solar Power 65 10-01-2008 11:08 AM
Solar panel installation jglase Generators & Solar Power 9 11-30-2006 10:47 PM
Solar Panel gilmorris Generators & Solar Power 14 12-05-2005 06:33 PM
Factory panel replacement till Ribs, Skins & Rivets 4 08-13-2004 11:46 AM
