03-27-2019, 09:51 AM
2019 30' Classic
Canfield
, Ohio
A very simple Solar panel support.
So after building my portable solar panel system, I needed an inexpensive, simple and easily broken down panel support system. I thought about building an aluminum frame "A" frame type, but threw that out the window due to complexity and weight. Looking around I had some 1 1/4" PVC schedule 40 pipe. At first, I thought that several legs and a cross piece for each panel would work best. I changed that to one leg per panel and that worked very well!
The 1 1/4" pipe also was overkill. I changed that to 1" pipe. Bought all the fittings and pipe at Home Depot for about $12. They also had 1" rubber feet that I needed to provide some friction between the panel and the frame.
I looked up the statistics for what angle I would need to best set the panels into the sun. Lots of data out there. Almost too much. I just came up with a nice angle which can be adjusted in many ways. The angle of the frame, the point where the panel touches the frame, the depth that you push the vertical supports into the ground are all ways to get different angles.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
03-27-2019, 09:53 AM
2019 30' Classic
Canfield
, Ohio
My solar panels are flexible. I bought and cut to fit, 1/4" PVC board to back the panels and give them more support. I add wire tent stakes to the bottom corners to provide more protection from them moving in the wind.
The frame is not glued together and can break down to it's smallest component if need be.
The panels will also fit in between the highest supports. I could add one more set and support the panels "in-between". That would allow me to add a string across the top of the panels securing them down from the wind. For now, this is the simplest design for me and should work fine and I could still add the string.
Tom & Doty
03-27-2019, 01:55 PM
Registered User
2016 25' Flying Cloud
Fairfield
Wonderful idea! Easier than what I concocted.
Does it need to be driven into the ground?
03-27-2019, 02:08 PM
2012 27' Flying Cloud
W
, New England
Very creative!
I think the dog helps too!
03-27-2019, 03:02 PM
2019 30' Classic
Canfield
, Ohio
Yes, it does. That's what helps give it the support. I cut the ends on a diagonal for this purpose. It is quite sturdy!
Tom & Doty
03-28-2019, 09:57 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
simple - and light - nice
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
03-28-2019, 10:34 AM
2002 25' Safari
Dewey
Simple solution, but I doubt it would work well everywhere. The ground in many of the locations out west is like concrete.
Richard
2018 30' Flying Cloud
Elgin
Excellent solution! Simple, flexible & storage friendly. Caz.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Simple question, probably not so simple answer
AWCHIEF |
Generators & Solar Power |
10 |
01-23-2016 03:23 PM |
2005 Airstream Bambi 19Ft. LS model-TV,DVD,Solar Panel,Very clean unit,GreatDeal
eBay Watch |
Airstreams on eBay |
0 |
11-16-2012 09:00 AM |
eBay Watch |
0 |
11-02-2012 06:30 PM |
eBay Watch |
0 |
10-26-2012 03:10 PM |
Simple question about low voltage dis panel schematic?
Mrcrowley |
Batteries, Univolts, Converters & Inverters |
10 |
08-18-2008 07:25 PM |
