Old 04-02-2006, 08:00 PM   #29
Pinky's Avatar
Maui , Hawaii
A few corrections to the prior post:
1. Solar panels fit very well on most Airstream roofs over 22 ft and I've met Airstreamers who live full-time with solar as their primary power source when boondocking
2. With panels on the roof there's no need to put the panels away when you leave, unlike a genset
3. I've read RoadKing Moe's posts on solar. I don't run all the stuff he lists. His argument seems to be basically "if you use a ton of power every day only a generator will do" What if you don't use a ton of power?
4. Your generator won't charge your battery fully either. At least not in less than 8-10 hours. Doesn't matter how big of a generator you have. You just can't tell without a sophisticated amp hour meter. Voltage doesn't tell you the true story.
5. "physics won't allow" people to use microwaves with an inverter and battery bank? Better tell a few people I know who do that all the time. They are likely to get put in jail for violating laws of physics!
"What are we going to do tomorrow night, Brain?"
Pinky is offline   Reply With Quote
Old 04-02-2006, 08:24 PM   #30
BeBop's Avatar
2000 27' Safari
Berkeley , California
I discovered this link a while back. It might have some relevancy regarding the portable solar panel discussion.
http://www.fiberglassrv.com/solar.html
'00 Safari 27' Rear Twin
'03 Ford F-250 7.3TD/CC/LB 4x2 Bio-Diesel
"Hmmm... Smells like French Fries!"
Prodigy/Enkay/Hensley/Solar/LED lighting
AIR 4598 / WBCCI FCU 8579/
EAA 872814
BeBop is offline   Reply With Quote
Old 04-03-2006, 08:54 PM   #31
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Mobile 12v Microwaving?
Pinky,
Is the 12v microwaver in a trailer or a home, off the grid?
Does anyone else do this in an Airstream?
R
fastrob is offline   Reply With Quote
Old 04-04-2006, 04:58 AM   #32
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
To answer the original poster's question, a solar panel mounted horizontally on an RV roof, and not shaded by the air-conditioner, etc., puts out in daily amp-hours about 1/4 of its wattage rating around the summer solstice, and about 2/3 of that around the spring and fall equinoxes. This is a rule of thumb that has developed over the years and verified by many RVer's who measure battery input/output with an amp-hour meter. Charging is only about 90% efficient, so multiply your daily panel output by 0.9 to find your "usable" amp-hours.
Before you decide how much of that you can use, you have to subtract that used by your RV, for the LP detector, the circuit boards in the appliances like the refrigerator and water heater, and the radio remembering its station settings. One way to find this is to turn everything off in the trailer, remove the negative lead from both batteries, then using a multimeter than can measure DC current between one of the negative leads and the negative post on its battery. Multiply that times 24 hours to get daily amp-hours.
Many RV appliances today have electric solenoids that control the propane flow. While the multimeter is still connected, turn on the refrigerator on gas and the water heater, one at a time, and record any increase in current. This you will multiply by 24 hours and again mulitply by the duty-cycle, the percent of time the solenoid is "on." That's hard to estimate and one of the best reasons for using an amp-hour meter.
You can also turn one light or other appliance on, and note its current draw over the base amount. Just don't exceed the rating of your meter. The one appliance that will probably draw the most power would be your furnance, and on larger RVs its fan can exceed the rating of a 10A meter. So can smaller furnaces during fan start-up. One worth checking is the Fantastic Vent fan since using solar means you park in the sun.
You may be surprised, especially with a larger RV, just how much electric power you use.
Maurice
Old 04-04-2006, 07:14 AM   #33
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
A few guys here at work have microwaves in their vans. One fellow I know only has a 750 watt inverter.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 10-28-2006, 08:09 PM   #34
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Well, I’m getting closer to ordering a 23’ Safari with L-Lounge from JC…
With 2 Fantastic Fans… and I’m considering Solar Panel(s)…
Does anyone know if JC can put 2 Solar Panels up there on the 23’ model
And if the AGM battery(s) are typically placed in the battery box outside…
Or if the factory places them inside (under lounge) taking up more space?
Bill
SilverGate is offline   Reply With Quote
Old 10-28-2006, 10:51 PM   #35
TIMEMACHINE's Avatar
Huntington Beach , California
outside
Pretty sure the batteries stay in the box outside on the A- frame just behind the LPG tanks.
TIMEMACHINE is offline   Reply With Quote
Old 10-29-2006, 01:04 AM   #36
2007 25' Safari FB SE
Suburbia , Sunny So Cal
While winter boondocking I use a Honda 1000 and a battery charger hooked to the batteries. Very quiet and in a couple of hours I'm all charged up and ready to run the heater all night.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 10:22 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 07:47 AM
