Old 03-20-2006, 03:48 PM   #15
2006 19' International CCD
Arroyo Seco , New Mexico
2airishuman
i've been looking for that honda 2000 under 900. w/shipping, you have a link?
JohnnieWinon is offline   Reply With Quote
Old 03-20-2006, 03:50 PM   #16
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
2 Air,
I know that Glass Mats don't gas, but I don't know for certain if they are immune to sulfation.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 03-20-2006, 04:16 PM   #17
_
hi johnnie....
purchased mine from mayberry......as many here have.....
they were at 879$ last year.....and until they won some sort of honda sales contest.....the the price changed.
ball power equipment, in parkville mo, is at 899$.....currently.....
1.877.225.5200.....free shipping in lower 48.......
couldn't find a web site for ball, but they do have an ad on pg 110 of march 'trailer life'.......
i talked with bob ball the boss.....last week. nice guy and informed
mayberry's ad is on pg 112......but no longer lists a price......
cheers
2air'
hey how's the mtn biking in your area?....
loved the movie "off the map" which was about a tax collector who became an artist...in new mexico....
Old 03-20-2006, 05:56 PM   #18
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Those solar panel were intended to basicly take the batteries back up very slowly. I have the solar option and well as a Honda EU2000i (soon to be propane). Should work well... 106 watts is 106 watts. a few light bulbs and all your solar gain is gone.....
Michelle TAC MT-0
Sarah, Snowball
Old 03-20-2006, 07:06 PM   #19
CanoeStream's Avatar
St. Cloud , Minnesota
Propane Powered Honda
Here is Pick's thread that Silvertwinkie mentioned earlier: Propane Powered EU2000i. I've kept the link for reference. This is most certainly something I'll be doing -- probably next fall.
5 meter Langford Nahanni
Old 03-21-2006, 10:01 AM   #20
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I'm close to pulling the trigger for a new Yamaha - 3-way per Silvertwinkie's link. Even though it is expensive to go that route, I have found that I am long-term happy if I buy good stuff and buy it once. In three years I won't be wishing I had spent the higher marginal cost.
But RE generators in general: the comments about "I can't hear it from inside".... Of course you can't. But your neighbor can - even the quiet ones. Be kind.
Pat. By the way - the pretty one on the left is Page. The old guy is me.
pmclemore is offline   Reply With Quote
Old 03-21-2006, 12:08 PM   #21
Airstream25's Avatar
1995 25' Excella
1982 34' Limited
Albuquerque , New Mexico
Images: 21
Send a message via Skype™ to Airstream25
53 watt panel can't quite keep up with usage
i have a 19' CCD with the solar option.
No matter how conservative we are with power the 53 watt panel can't quite keep up with usage, esp in the winter months. After 'bout 4 days we are down to 40% power, even with mostly full sun.
i am thinking about adding an additional panel. What i am thinking is a panel on the ground that i plug into the airstream solar system.
Where to purchase.
I put a 120 watt Kyocera panel on the roof and it does keep up with my usage for extended boondocking.
I had briefly considered a ground panel because I could tilt it as required to directly face the sun. However, the panels are expensive, heavy and fragile. I was concerned that the handling would eventually cause damage. Also, our NM spring winds would require a strong ground mount to hold it securely.
Solar panels are available from http://store.solar-electric.com/kc-120.html
amoung others.
Airstream25
KE5CKG on 2 meters
AIR #10274
Airstream25 is offline   Reply With Quote
Old 03-21-2006, 12:23 PM   #22
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
I think that all A/S owners can benefit from switching the standard converter to a more efficient model which is intended to focus on the batteries (I switched to the Intellipower, but there are others)
That said, I do a lot of boondocking and I find that if I run my Honda i2000 4 hours ever other day I can keep my 2/12V lead acid batteries above 80%. Also, I plan any high power and or 110v activities during the 4 hour juice time, ie: Microwave cooking/electric barbeque, 48"plasma TV with Bose 9 speaker surround sound system, and Dysan upright vacuum cleaner.
Ooo, did I catch a whiff of ozone, sniff, sniff?
Michael
ArtStream is offline   Reply With Quote
Old 04-01-2006, 07:51 PM   #23
Zugbug's Avatar
Volcano , California
Isn't this thread abpout using a solar panel? I know a lot of folks use generators but I would like to try and get by without one. I just purchased an 85 watt panel that I will use free standing. I hope to extend my boondocking usage to 5 or 6 days with limited power usage. Meaning no heater only some lights in the evenings. Has anyone got a link to power consumption and recharge capacity?
Zugbug
Zugbug is offline   Reply With Quote
Old 04-01-2006, 08:13 PM   #24
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Michael
Wow, How do you fit that 48" rascal in the rig? Theater seating? Mine came with a 13" B&W which I gave away. Imagine running that thing off solar panels, you would need reflectors and multiple big panels. Sounds wild!
R
fastrob is offline   Reply With Quote
Old 04-01-2006, 08:47 PM   #25
_
Zugbug
hi zugbug
if you are expecting threads to stick with only one topic......good luck!!!
looks like the person starting the thread asked several questions about gen sets....after the initial solar question....
as for a link to power consumption and recharging issues......go to advanced search and enter solar + power ratings....or some such key words....many threads will appear....
roadkingmoe has posted many of the numbers related to how much power is drawn and how much is replaced and at what rate...so if you put his name in the search it will narrow the returns....
several of the solar vendors also provide budget/supply/inventory forms so one can calculate power needs and solar returns...
i think solar can extend boondocking to 5-6 days....if you really only plan limited 12v lights? what about the contol boards for the fridge, water heater, water pump and so on....do a full inventory of 12 volt requirements....it adds up.
happy searching...
2air'
Old 04-01-2006, 09:02 PM   #26
1995 25' Excella
1982 34' Limited
Images: 21
My preference is solar due to no operating cost or noise or fumes.
We economize on power consumption by switching out half of the incandescant bulbs with low power LEDs. Some are base compatible so it is just a matter of unscrewing one and screwing in the other.
Candles during dinner in the evening are so nice that we would use them even if we were not trying to economize on power consumption.
Here is a web site for LEDs.
http://home.tiac.net/~jtdjtd/aspix/LED/LED.html
Airstream25
KE5CKG on 2 meters
AIR #10274
Old 04-02-2006, 08:39 AM   #27
1972 29' Ambassador
1968 22' Safari
Tyler , Texas
LED's for power economy
I installed a 15W solar panel on my AS just to keep the deep cycle marine battery topped up while it sits in the storage yard. The AS gets weekend visits from me to bring the interior up to habitability. I also have a separate small starting battery (it came from my son's wrecked Nissan sports car) that I keep topped up with a little 5W Volkswagen window charging unit. I use this battery with an inverter to run power drills and so forth.
Almost as an experiment, I've started replacing selected 12V lamps with LED arrays that I bought from Super LED's. The square 36-LED red arrays that have a standard bayonet plug work just great in groups of 2 to replace the overhead first-setting lights and provide plenty of light to get around in the trailer at night. I've also replaced the recessed reading lamps over the gaucho with white-light arrays, the over-door step light with an amber LED array, and the always-on control panel indicator lights with single LED's from Radio Shack. When all of them are on at the same time, the drop in battery voltage is only about half a volt! After many hours of night use, the solar panel is able to bring the big battery up to capacity after only a few hours of sun, too.
I think you could boondock for a long time with this type of setup!
26.982 amu is offline   Reply With Quote
Old 04-02-2006, 03:23 PM   #28
Many good points have been made. This post picks up some crumbs... None of the following assume the extra demand of operating air conditioning -- whether while boondocking or (sadly) in the tow vehicle while towing.
Pick's LP conversion is at Propane Powered EU2000i. I've got to strap down a variety of things in my pickup box to prevent them flying on impact or sudden maneuver. I haven't done the conversion to my Honda yet but not having the volatile gasoline makes sense to me.
I do not agree with the statement that solar has no operating cost. It requires the highest investment of any option and then only meets part of your power requirements. Read RoadKingMoe as referred to before (best threads would take more research time than I have right now -- but Maurice is knowledgeable & insightful!). There also are too many obstructions on an Airstream roof to install more than a modest area of panel. If we take this to the extreme of standing some solar panel on the ground in the campsite (staked down against any wind of course ... and gosh, maybe even a satellite dish!!), what will you feel compelled to do with the thou$and$ standing out there if you want to go fishing or to a restaurant in town? Putting the genset back in the truck is likely; I haven't seen a personal need for a larger genset (Yamaha or 2 EU2000i's) for A/C as those members in the South might require.
If you already have the factory solar (I chose not to do that. I am not in New Mexico like the thread starter.), it seems a genset and solar strike a happy medium of evening peaking power from the genset and some maintenance charging from the solar. Interesting statement above that the factory solar won't take you up to 100%...
And recall that physics just won't allow use of batteries and an inverter to run a true power electric accessory like a microwave (or toaster or iron...). We're talking boondocking, remember?
Do not forget that most tow vehicle alternators are closely tuned to the tow vehicle needs and have so little extra capacity that it may take 200-300 miles of towing before the tow vehicle can significantly charge your coach batteries. If you run tow vehicle accessories like A/C or headlights, figure on greater distances between recharges.
IMHO we all need to understand how much time we spend at sites with or without plugin capability. Your onboard convertor will prepare you before you leave home and assist greatly if plugged in every few nights while on the road.
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 10:22 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 07:47 AM
