Old 05-26-2010, 08:08 AM   #1
Waxhaw , North Carolina
89 Onan 6.5 Generator
I seem to be having a severe problem here. The motor runs when the switch is held on but when you let go, it just shuts off. Anyone know what might be going on??
MSarif is offline   Reply With Quote
Old 05-26-2010, 08:34 AM   #2
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Check the oil level. When it is low on oil it has an automatic shut off.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is online now   Reply With Quote
Old 05-26-2010, 08:59 AM   #3
Bandits's Avatar
2008 30' Classic
I would need to look at the electrical schematics. If I had a problem in the type of machinery that I work on I would go straight to the latch relay, generally on the contactor for the motor involved. I don't know much about rv generators so your system may not even have any contactors or relays.
Jerry, Irene & Clancy
Bandits is offline   Reply With Quote
Old 07-21-2010, 04:29 PM   #4
Kenosha , Wisconsin
onan start problem
Onans have a severe problem with the control relay on the circuit board. this relay wears out and cannot be replaced alone, the board needs to be replaced.
We see maybe 50-60 units a month with the same problem.
Gentech is offline   Reply With Quote
Old 07-21-2010, 05:20 PM   #5
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
start with the easy stuff
make sure the switch is operating correctly in the "run" position.
ol' bill
wmarsha is offline   Reply With Quote
Old 10-25-2012, 01:35 AM   #6
1971 29' Ambassador
guyton , Georgia
plugs work but no ac work when gen is running everthing works on shore power
r.swanson is offline   Reply With Quote
Onan Generator gunworks Land Yacht/Legacy Motorhomes 7 07-22-2009 08:46 PM
Onan Generator 87MH Mechanics Corner - Engines, Transmission & More... 34 07-10-2007 07:26 AM
Onan Generator Hillgenberg Generators & Solar Power 2 08-24-2006 12:32 PM
onan generator Bozair General Motorhome Topics 6 01-27-2005 07:34 PM
Generator onan Paul Daugherty Airstream Motorhome Forums 6 11-26-2002 12:51 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
