Old 08-19-2014, 02:55 PM   #1
2016 25' International
Wanamingo , Minnesota
#6 Solar wire entry hole question.
I just purchased a solar system from AM Solar. I am installing two solar panels on the roof of our 2008 23D International. My plan is to mount a junction box above the refrigerator/microwave on the roof outside. I will need to cut a 1" diameter hole in the roof. Any thoughts on problems I may have using this location? I have removed the microwave & on attached picture you can see where I plan on cutting hole in the ceiling & roof. I want to route the wire down into the refrigerator compartment (behind refrigerator, accessing through outside door), then drill a hole in the floor below the refrigerator (above the roadside wheel well) so I can run it under the gaucho to the batteries.
I want to avoid cutting a hole & into something between the walls that will cause problems or damage.
ID:	219385   Click image for larger version
Scout1 is offline   Reply With Quote
Old 08-19-2014, 07:05 PM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We just came down the refrigerator chimney on the roof so no extra holes were needed on the roof. We used the space behind the refrigerator as a duct space to take the wires whee we needed them. We put the solar isolation switch inside that space beside the refrigerator access hatch.
We put 8 100 watt AM Solar panels on the roof and the WiFi Ranger and Verizon extern ion antenna for their modem on the tool of the refrigerator chimney.
Old 08-19-2014, 07:19 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
I just finished a 23 installation and upgrade last month and that is the exact spot that I used for the solar wire. Of course, the dealer had buggered up the hole that they made in the same spot using NO BUSHING in the hole so that the old cable from the panel that they installed had rubbed thru the insulation! It looked like they cut the hole with a jig saw rather than a hole saw!!!!!!
You have a continuous run from that area up front for the charge controller and monitor panel. You need to be a bit creative with the wire runs and fish tape, though.
Old 08-20-2014, 11:06 AM   #4
Thanks for the reply. The 23D International has no refrigerator vent on the roof....thus the need for a hole.
Old 08-20-2014, 11:24 AM   #5
Lewster,
I think you were replying to my post about routing the wire through the roof above the microwave on the 23D Airstream. Did you run the wire behind the refrigerator then through the floor under the refrigerator, exiting just above the street side wheel well? Any cautions about where to cut the 1" hole above the microwave?
Solar panel wire routing question Scout1 Generators & Solar Power 11 09-04-2014 06:36 PM
Best wire connector for 12 gauge stranded wire jcarnevale Lights - Interior & Exterior 6 04-14-2014 08:18 PM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
