Old 06-23-2009, 04:13 PM   #1
crashxx's Avatar
1983 30' Airstream 300
Weatherford , Oklahoma
50 amp conversion or 30/20 amp setup
I had an idea. It doesn't happen often but sometimes I get one. In my 83' 300 classic, there is an automatic transfer switch that engages when the power from the generator is applied to the coil. The idea I had was, couldn't you put one on the seperate 110v circuit for the second a/c where the default position is power from the generator and the tripped position is from another 110v 20 amp external power source? I thought I could put a plug somewhere on the exterior and using a seperate extension cord plug into another 110v circuit to run the #2 a/c. What do you think?
crashxx is offline   Reply With Quote
Old 06-23-2009, 05:32 PM   #2
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
I am trying the same idea...I just hard wired the rear A/C to a extra plug down beside the main 30a connection.
That way I can plug the rear A/C into a regular 120v socket at campgrounds, and use the 30amp for front air and cooking etc.
I disconnected the feed from rotary switch to rear so I never feed power from two directions.
And I put dummy plug onto end of cord while traveling.
There must be a better way, but I could not figure out how the rear air received power direct from generator, without power showing up at generator when pluged in and switched to rear.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 06-24-2009, 07:59 AM   #3
crashxx's Avatar
I'm going to try the automatic switch. It may be a month or so, but I'll post my results when I get it done.
Honda Pair With 30 amp Parallel Setup Cracker Generators & Solar Power 11 04-24-2008 12:19 PM
30 to 50 amp conversion Honkity Hank Classic Motorhomes 25 03-29-2006 08:51 PM
Reese WD & dual cam chain setup Safari64 Hitches, Couplers & Balls 21 03-19-2006 12:19 AM
Brakesmart & Hensley setup Dwight Hitches, Couplers & Balls 9 02-26-2005 10:41 AM
