Old 05-27-2008, 08:32 AM   #1
mandolindave's Avatar
30 amp service at home
I have installed the 2" conduit, now the fun begins. I am installing the 30 amp serviice, along with a switchable 20 amp circuit for lighting, on a pole near the camper. The RV outlet from Connecticut Electric came with no wiring diagram. Which contact is hot? Also I would be very interested and appreciative for any photos of outlet boxes and such that others members are using.
P.S. I have tried the search function using all kinds of variations of keywords and the first 3 suggested threads were a rally, a music poll, and a word challenge game. I pity the newbie who asks a question only to get told to use the search function. I never have much luck with that.
mandolindave is offline   Reply With Quote
Old 05-27-2008, 08:46 AM   #2
Elgin , Texas
Images: 164
Hi Dave. Typically the outlet connector screws will be different in color - the hot lead will be a gold screw, the neutral is silver, and the ground is green.
Here is the external orientation.
bake315 is offline   Reply With Quote
Old 05-27-2008, 08:49 AM   #3
Old_Town's Avatar
North East , Texas
Look at the screws
The gold colored screw is always the hot and the silver colored is always the neutral and of course the green screw is the ground.
Old_Town is offline   Reply With Quote
Old 05-27-2008, 09:48 AM   #4
Thanks for the speedy reply
My screws are red and silver. Obviously the red is hot. Your diagram is most helpful for a guy like me who has one screw loose.
I would be interested in any other pictures of outlet setups.
Old 05-27-2008, 10:08 AM   #5
Elgin , Texas
Images: 164
I did my own install recently. I'll try to get a snapshot of it for you.
Old 05-27-2008, 10:28 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Since my breakers are located close to where I stage and destage my trailer my setup was a piece of cake. I attached the outlet in an outdoor box under the panel. Total wire length of wire is less then 1 foot.
Richard
Old 05-27-2008, 11:41 AM   #7
Over59's Avatar
Putnam , Connecticut
Images: 37
What size wire are you using and how long is the run to the main panel? Are you planning on doing the hook up on the panel side yourself?
Over59 is offline   Reply With Quote
Old 05-27-2008, 12:20 PM   #8
I am comfortable around the panel...BUT.....
I might enlist a friend who is licensed, for the panel connection. I like the ring of Mandolindave much more than Sparkydave. But if you have any tips on the panel connection, please do pass them along to me. The outside run is 48', adding the inside run and the run up the pole adds up to 75'. I am using 8 gauge underground cable.
The project is multi purpose. The lady of the house doesn't care for air conditioning, but if it gets hot I would like a cool place to hang out. I am also putting in lighting for the campfire area and huge motion detector light so she knows when bear are doing things in my yard insead of the woods where they are supposed to. Soon I will be breaking ground for the barn, and I will want electric there as well.
Old 05-27-2008, 01:18 PM   #9
Over59's Avatar
Images: 37
You may want to check this out.
Copper.org: Electrical: Energy Efficiency - One Wire Size Up Means Big Savings
Old 05-27-2008, 02:04 PM   #10
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
Originally Posted by Over59
i just read that article and feel that i may have under sized my wire.
unlike azflycaster i had to make a 250ft run to my staging area. i got a quote from a spark for installing a 30A for RV and 20A GFCI for pool then decided to DIY the most of it. I then called in a favor from a friend to wire the receptacles in.
considering the fridge is the only constant draw, is the 10/2 that was recommend fat enough for 30A?
elbundi is offline   Reply With Quote
Old 05-27-2008, 03:23 PM   #11
Elgin , Texas
Images: 164
10/2 seems awfully light for a 250' run. Regardless of the draw from the refrigerator, if you have roof air (or want to have it in the future) I think you're definitely going to come up short in amp capacity.
Old 05-27-2008, 03:38 PM   #12
2002 25' Safari
Dewey , Arizona
Images: 62
You can plug your numbers into this calculator to determine the wire size required. 5 amps is the max for 250 feet with #10 wire. Your refrigerator may only pull 5 amps, but don't forget your converter will draw a couple of amps too.
Richard
Old 06-01-2008, 09:10 PM   #13
elbundi's Avatar
Leesburg , Georgia
re assessing the situation
although it was a reputable company that made the quote, i am going to re-evaluate
hindsight says running 2 inch conduit with 6 gauge wire would've been the smarter choice.
we're moving house so may just retire that particular line and let it be.
C & G Trailer Service, Bellflower, CA Safari-Rick Commercial Listings 18 05-31-2014 05:49 PM
Axle Alignment & other service ?s dpandorf Axles 0 05-15-2008 10:58 AM
30 Amp service at home 68 Overlander Commercial Listings 0 07-15-2007 11:13 PM
hook-up options for a 50 amp service nyulman Electrical - Systems, Generators, Batteries & Solar 4 01-13-2007 09:45 AM
50 amp service available mtnman Electrical - Systems, Generators, Batteries & Solar 10 04-29-2006 05:11 AM
