Old 11-09-2014, 07:02 PM   #1
Keith Gantt's Avatar
2014 23' Flying Cloud
Woodstock , Georgia
23fb solar panels for under $400
I added two 100watt solar panels with control panel from Renolgy purchased from Amazon . Mounting hardware from Ace (rubber plug nuts and stainless screws ) added a sealed gel battery and box with on/off circuit breaker to isolate when you want back up incase you run two stock batteries dead. A wall mounted volt meter gives you the number anytime tank monitor switched on.
Solar kit $239.00
Volt meter $1.00
Battery box $9.99
Battery $139.99
Circuit breaker $6.99Click image for larger version
Name:	ImageUploadedByAirstream Forums1415581063.964460.jpg
ID:	226130Click image for larger version
Name:	ImageUploadedByAirstream Forums1415581130.688989.jpg
ID:	226131Click image for larger version
Name:	ImageUploadedByAirstream Forums1415581178.898921.jpg
ID:	226132Click image for larger version
Name:	ImageUploadedByAirstream Forums1415581247.535305.jpg
ID:	226133Click image for larger version
Name:	ImageUploadedByAirstream Forums1415581294.841676.jpg
ID:	226134Click image for larger version
Name:	ImageUploadedByAirstream Forums1415581325.502514.jpg
The Streaming Gantt's on Airstream Forums
Keith Gantt is offline   Reply With Quote
Old 11-09-2014, 07:21 PM   #2
indy's Avatar
1962 22' Safari
kansas city , Missouri
Images: 22
Nice!
I to added two 100watt Renolgy but chose to keep them portable.
First trip this summer and wow do they work!
Full charge by 10 am and even during rain storms! So fun to watch the amps flow in!
indy is offline   Reply With Quote
Old 11-09-2014, 07:29 PM   #3
indy's Avatar
1962 22' Safari
Images: 22
ID:	226140 love power from the sun, so quite.
Old 11-09-2014, 07:34 PM   #4
Woodstock , Georgia
8 days semi shaded spot at Elkmont in Smoky mnts with 4 people,showers daily, lights fridge, music lights etc no problem. Even ran the heat two nights. Click image for larger version
Name:	ImageUploadedByAirstream Forums1415583204.848677.jpg
ID:	226141Click image for larger version
Name:	ImageUploadedByAirstream Forums1415583253.441666.jpg
Old 11-09-2014, 07:42 PM   #5
indy's Avatar
1962 22' Safari
Images: 22
Freedom! From the cord.
Old 11-09-2014, 08:01 PM   #6
Woodstock , Georgia
It's truly a good feeling to enjoy all the comforts day after day with no guilt.
Old 11-09-2014, 10:41 PM   #7
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Awesome!!!!
Skatiero is offline   Reply With Quote
Old 11-10-2014, 12:51 PM   #8
Look for us at Assateague
1975 31' Sovereign
1955 22' Safari
Ringoes , New Jersey
Voltage?
Hi: I also mounted solar modules on my vintage 1955 and 1975 Airstream trailers and added extra batteries. I was wondering, with two 100-watt modules, what is the voltage DC of each? Did you connect them in serial or parallel before connecting them to your charge controller? Thanks.
thompooley is offline   Reply With Quote
Old 11-10-2014, 12:59 PM   #9
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Excellent work! And not a huge expense. Bookmarking for future reference.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-10-2014, 03:40 PM   #10
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
Ditto
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 11-11-2014, 07:27 AM   #11
indy's Avatar
1962 22' Safari
Images: 22
Renolgy, say they run at max 18.9dc volts and I run mine parallel to the controller.
A lot of info out there, this is a blog of info I continue to refer to.
HandyBob's Blog « Making off grid RV electrical systems work
Old 11-11-2014, 07:52 AM   #12
indy's Avatar
1962 22' Safari
Images: 22
My intention is to be able to recharge the house battery and a trolling motor battery at the same time.
Water Shutoffs Under the Pantry ... 23FB TinTin 2009-2015 Flying Cloud 3 09-17-2014 08:13 PM
Adding panels on top of panels instead of replacing? The-Marco Ribs, Skins & Rivets 18 08-02-2014 05:53 PM
*******2012 Airstream 23FB Flying Cloud, Solar Option As New, Never Used****** eBay Watch Airstreams on eBay 0 10-30-2011 07:10 PM
*******2012 Airstream 23FB Flying Cloud, Solar Option As New, Never Used****** eBay Watch Airstreams on eBay 0 10-23-2011 10:10 AM
Under Panels jperryfly Belly Pans & Banana Wraps 31 06-30-2004 10:35 PM
