Old 12-19-2014, 08:16 PM   #15
ottawa (greely) , Ontario
Originally Posted by dznf0g View Post
Sounds like the 80W Go Pro comes with a large enough capacity controller for 240 watts. You can add as many as you want, with proper wiring and a larger capacity controller....within reason.
Go power. 80 watt and 120 watt portable folding panels have a 10 amp charge controller .so the maximum wattage would be somewere around 135 watts of solar panel.
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 12-20-2014, 07:26 AM   #16
dznf0g's Avatar
Oswego , Illinois
Don
So when they say up to two more can be added, they must require a different controller?
-Rich-
Old 12-20-2014, 01:18 PM   #17
2005 22' International CCD
Cambria , California
This will sound weird but if you have more than one panel, you should keep the wires at the exact same length. I don't know why but I was told this by several good sources when I put solar on my 22ft CCD. My suggestion to you is that you permanently install the panels and controller and increase the size of the batteries. I have four 80 watt panels attached to the roof, an excellent charge controller and made bigger battery boxes using two Trojan 6 volt high capacity deep cycle batteries in series. We camp for two weeks at a time running the furnace, watching movies and never run out of power unless we are in dense shade. Even then, we just have to conserve a little.
Ziggy2 is offline   Reply With Quote
Old 12-20-2014, 01:44 PM   #18
mefly2's Avatar
2015 25' FB Eddie Bauer
We use a briefcase Goal Zero and a folding Zamp (for sale) together and they seem to charge fine ... maybe I missed something...connect one to the AS batts and one to the TV batts and it appears to charge the AS batts through the umbilical ...
For us and our electrical usage, the two units seem to be overkill in all but the late fall - when we need more batt power for the furnace fan and there is less available sunlight.
Old 12-20-2014, 06:09 PM   #19
lewster's Avatar
Naples, FL , Hood River, OR
I don't know who your 'good sources' are, but if you are using proper sized cables (we use 10AWG from each cable to a combiner box) and then a sufficiently large cable to carry the voltage to the controller and then the charging current to the batteries, there is no need to use cables of the same size. this is because there is extremely small to no voltage drop measurable in our systems.
I just finished a 12 panel system with 160 watt panels and 3 paralleled charge controllers, and the cable lengths ranged from 15' to 4'. There was no appreciable voltage drop (it was measured in the first set of 4 panels to be virtually identical)....so no reason to use identical sized cables. The system has a 120 amp total charge capacity to the batteries of the motor home.
It might be an issue if you use minimal sized cables where the resistance and voltage drop in the cable runs are appreciable, but we never see this problem.
Old 12-20-2014, 06:25 PM   #20
2 Portable Solar Systems
Yes, sounds weird but I talked with either the charge controller people or the Sanyo people and some others and they all concurred that it was optimal for performance to have the cables the same size. I have no idea why and it may make a minimal difference but I thought, it can't hurt.
Old 12-20-2014, 06:27 PM   #21
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I think the wires need to be the same length, because if they are of unequal length, there is a small but definite chance that the solar karma of the panels could become 180 degrees out of phase. This would cause them to start disliking each other and refuse to work together. At least that's what MY sources said.
Ken
Old 12-20-2014, 06:32 PM   #22
Ag&Au's Avatar
The key factor here is what does optimal mean. As Lew stated, if the cable is of sufficient diameter, then any deviation from optimal will be infinitesimal. However if it makes you feel better, knock yourself out getting them exact. Just make sure the wires are at the exact same temperature when you measure and cut them.
Ken
Old 12-20-2014, 06:36 PM   #23
Hey, I didn't come up with this. Sites like cleangreenenergyzone.com say things like this " Q: Is the length of the cable important when connecting the solar cells?
A: The cables should be short enough and have the same length." It can't hurt
Old 12-20-2014, 06:38 PM   #24
If you look at the go power web site under accessories or expansion kits you have to read between the lines because what there saying for expansion is the portable 40,80 or120 watt is the expansion to your already permanent solar panels on your trailer. And all three kits have the same 10 amp charge controller( not the greatest PWM) a much better charge controller would be a mppt charge controller but this would drive the price up, the mppt charge controller would harvest up to 30 % more power out of the same solar panels.
Don
Old 12-20-2014, 06:48 PM   #25
Ag&Au's Avatar
I'm a sorry, but even after extensive rehab, I am still an incurable smart-ass. I just find it annoying when authorities, such as you quote, give a blanket -one size fits all- answer without explaining what other variables can effect the real answer to a question. For instance, using their apparent emphasis, if the cables were of different diameter then they should be of particular unequal lengths. In your case making the leads the same length may be no big deal. However in a different situation the possible mounting options might make it a PITA to make one wire unnecessarily long just to satisfy their made up equal rule.
Ken
Old 03-14-2015, 11:42 PM   #26
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
I have been pondering portable solar panels for a few months, reading discussions like those above. At my introductory stage, I just want a suitcase kit that I can connect in the sun in a few minutes. It sounds like several members of this forum have been happy with 80 watts, but it might be most efficient to buy a kit that provides 100, 120 or 160 watts. Assuming that each kit is truly complete, perhaps except for addition of a longer extension cable to allow more flexibility to position the panels in the sunlight, the top choices seem to be:
RenogyⓇ Foldable Solar Suitcase Battery Charger 100W
Buy new: $269.99
3Used & newfrom $269.99
Go Power! GP-PSK-120 120W Portable Folding Solar Kit with 10 Amp Sola…
Buy new: $623.95
13Used & newfrom $543.99
Zamp Solar 160 Watt Portable Ch...Zamp Solar 160 Watt Portable...Zamp Solar 160 Watt Port...
$755.00
Solar DealzSolar
Zamp Solar 160 Watt Portable Charging System $755.00
Solar Dealz
Great for dual-battery banks / moderate users
or
Zamp Solar 120 Watt Portable Ch...Zamp Solar 120 Watt Portable...Zamp Solar 120 Watt Port...
$627.00
Solar DealzSolar
Granted that shopping more websites of additional vendors might shave a few dollars off any particular kit, it seems like a huge jump in price from the Renogy 100W kit at about $270 to 120W kits at approx. $625 or 160W kits at approx. $755. To increase from the Renogy 100W kit to the others more than doubles the price. The kit prices seem to increase exponentially with increased wattage, rather than linearly. Perhaps that is appropriate; I don't know.
Please comment on the "value" and "cost effectiveness" of these comparative solar panel kits. I am a newbie so I don't really know what demands for power I will have, but I just want to get a good value for battery charging capability with easy, non-technical set-up that I can easily carry in the Airstream while driving. It seems like purchase of a Honda EU2000 generator may be a good idea sometime too, but I would prefer to start with solar, so will wait until I have some Airstreaming history before adding a generator, if I ever do.
I welcome any advice and comments.
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Old 03-15-2015, 09:31 AM   #27
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The Renogy system listed seems to be one of the better portable set ups on the market. Reviews are overall very good and it has a very competitive price.
MICHAEL
Old 03-15-2015, 10:17 AM   #28
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
If it has any bearing, I got 3 100W flex panels from Renogy.
The folks there were great to deal with and the panels are working as advertised.
I would have no hesitation in buying there again.
George
gandttimes is online now   Reply With Quote
Portable GPS systems JakBluMule On The Road... 100 05-26-2008 06:58 PM
Cleaning the portable water systems after use Silvertwinkie Fresh Water Systems 4 07-01-2003 03:46 PM
