Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 02-15-2005, 07:51 PM   #1
Kistler
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
#2 attempt--any recommendations for a solar charger?
I would like to find/buy solar chargers that have alligator clips and can be attached to the "forehead" of the trailer.
Do any of you have recommendations as to brand, etc.?
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 02-15-2005, 08:01 PM   #2
Condoluminum
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
I suspect lack of responses due to wide range of options... First question is size and wattage, and intended purpose, as some little solar panels from auto parts stores might provide trickle battery maintainer charge through cigarette lighter plug from inside, or you could swap plug for alligator clips with parts and splice connectors from Radio Shack. They would protect battery from drain when parked and stored, but not much more...
If you want enough watts to replenish battery drain daily from lights, water pump, fans, etc while dry camped, that's a large panel like a Siemens, with potential permanent mount, and suggestion would be to just run through charging regulator and mount permanently... THere are some threads you can search here using search box (upper right) on "solar" and see what others have done, or find names to consider private messages to..
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 02-15-2005, 08:04 PM   #3
driftwood
Remember Burma Shave!
driftwood's Avatar
Profile:  1985 25' Sovereign
1965 22' Safari
Excursion V-10 , S.Florida
Images: 35
Maybe here?
Have you tried calling these people?
http://www.rvsolarelectric.com/
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 02-15-2005, 09:04 PM   #4
Kistler
Kistler's Avatar
Thanks you guys! "#2 attempt" is/was referring to the fact I have trouble posting a new topic on this forum I'm technically challenged!
I just want a trickle charger for maintenance!
Kistler
Old 02-15-2005, 09:07 PM   #5
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
www.rvsolarelectric.com has a great small catalog which explains some of their systems available. Of course, their website gives you much info also. You can order just about any size panel from them.
If I remember correctly www.unisolar.com (or do a search on unisolar) has flat panel systems as well as flexible panels. With a flexible you could stick suction cups on one end, let the flexible panel curve over the side of the trailer and stick 2 more suction cups on the lower end. This might take advantage of different angles of the sun but I couldn't say for certain. Off the top of my head I think they go up to 30 or 34 watt flexible panels and higher on the flat panels.
Check www.pulsetech.com for Solargizer solar chargers which I have had some great luck with. I think they still have 5 and 10 watt panels with multi-stage charging. www.batterymart.com has flat panel solar BatteryMINDer systems in 5 or 15 watts. They also offer 5, 10 and 20 watt flexible systems. I really like the batteryMINDer systems enough to recommend them to a friend who recently bought the 15 watt solid panel charger.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-15-2005, 09:37 PM   #6
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
I just saw one with that exact description on sale at either www.harborfreightusa.com or www.Northerntool.com in one of their sales flyers.
Found it... item 41144
http://www.harborfreightusa.com/usa/...o?itemid=41144
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 02-16-2005, 07:01 AM   #7
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
Are you going to disconnect the LP detector, which isn't disconnected when you shut the master battery switch off? Or do you need to power it 24 X 7 also? If so, you need to multiply its current draw by 24 hours to get daily amp-hour usage you'll have to replace.
Do you have AGMs (self-discharge 2-3% per month) or flooded cells (2-3% per week)? How many total amp-hours do those percentages apply to? For example, at 3% for 200 amp-hours, that's 6 amp-hours per week for flooded cells and the same per month for AGMs.
Solar cells laid flat provide about 25% of their wattage in amp-hours on a good day in the summer, about 17% in spring and fall, and as low as 5% in winter. This is reduced more by cloudy or rainy days, so allow for the appropriate number of days per week of that for your area.
Also keep in mind that charging efficiency is less than 100%. You'll need to supply about 110% of what's used.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
battery charger ALANSD Batteries, Univolts, Converters & Inverters 8 09-16-2007 05:52 PM
Solar Panel Installation 69Overlander Generators & Solar Power 23 11-19-2002 09:25 AM
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 10:22 AM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 07:47 AM
