Old 09-01-2016, 06:14 AM   #1
2016 30' Classic
Houston , Texas
15 Amp to 50 Amp Extension Cord - What gauge?
I have a Honda 2000i generator that has a 15 amp plug. Will use a 15 amp to 50 amp dog bone to connect my 2016 AS Classic with its 50 amp plug. Want to purchase an extension cord to get some distance separation between the AS and the running generator.
Regarding the extension cord, what gauge wire should I get? Thank you.
dhroberts is offline   Reply With Quote
Old 09-01-2016, 07:08 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If 50' or so 12 gauge. If it will be 100' use 10 gauge. Voltage drop is what you are trying to prevent. Even though it's only 15 amp max load.
Old 09-01-2016, 09:04 AM   #3
Boxite's Avatar
2008 22' Sport
You may do this either of two ways:
Buy a 50 Amp extension cord intended for RVs. ($150 and UP...)
<or>
Buy a 12 ga. 110 volt extension at any hardware store or Amazon. ($35)
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 09-01-2016, 09:23 AM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
... and of course there's a 3rd way.
You can get a 30A RV extension cord cheaper than the 50A, and it would let you run one AC if you needed that much cord to reach a 30A or 50A receptacle at some point. 95% of the time the heavy-gauge 15A cord will be plenty, but sometimes you can find a decent deal on a 30A cord. I mostly use my 30A extention for hooking up to the generator in the bed of the pickup.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 09-01-2016, 11:55 AM   #5
2014 27' FB International
Clearwater , Florida
I may be confused, but isn't the 50 Amp a 220 Volt service? And the 15 Amp is 115 Volt.. Now I am sure a adaptor could be made to power half the trailer circuits. Please correct me if I am wrong.
ChuckFeldt is offline   Reply With Quote
Old 09-01-2016, 12:00 PM   #6
r carl's Avatar
Lin , Ne
You are.
Old 09-01-2016, 12:28 PM   #7
2014 25' FB Flying Cloud
Mattituck , New York
we use a 30 amp to 15 amp marine adapter. It can be used right at the trailer for a short 12 gauge extension or on the generator using the long 30 amp cord for a lesser voltage drop. The larger cord allows for the single or twin operation of the Honda 2000.
darsea is offline   Reply With Quote
Old 09-01-2016, 12:59 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
A lot of people address this question as if the owner is going to push a 30 or 50 amp load with his single Honda or even a pair.
That ain't going to happen. A 10 gauge 30 amp RV cord is plenty (more than enough, (even a 12 ga cord will do for reasonable length runs)), and the gauge of the 30 to 50 dog bone is going to be meaningless because these are factory made and very short.
Gradiens super tenui glacie.
Old 09-01-2016, 01:07 PM   #9
Boxite's Avatar
2008 22' Sport
An advantage of the less-expensive method I posted above (110V 12 ga ext. cord) is that for those times you don't need 50' of distance from the power-source,... you have a 110v extension cord to plug into your outside/curbside outlet to power lighting, fans, tools, or other appliances when in a campsite.
Rambox
Old 09-01-2016, 03:02 PM   #10
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
A few thoughts...
- The Honda is quiet. Your 50 amp service cord is probably 25 or 30 feet. Why put the generator farther away? If you move it 50 or 100 feet away from your trailer it gives the thief an additional 50 or 100 foot head start. It also means a longer walk to start it, shut it down, check fuel, etc.. We typically run one Honda 2000 chained to the A frame and can't hear it in the back of the trailer if the windows are closed. If I run both of mine it's because we need AC and we can't hear them because the AC blower inside is louder than two 2000s right outside.
- A single Honda 2000 is not going to run your AC.
- 50 amp RV service is not 220 v. It is effectively two 110 v circuits. The appliances in a 50 amp served trailer are still 110 v, just like in a 30 amp served trailer
GammaDog is offline   Reply With Quote
Extension Cord Use & A/C J5MM Batteries, Univolts, Converters & Inverters 23 06-08-2016 09:38 PM
Length of standard 30 amp extension cord on trailer Lothlorian Electrical - Systems, Generators, Batteries & Solar 8 09-02-2015 08:56 PM
30 amp extension cord rbourdage Electrical - Systems, Generators, Batteries & Solar 16 04-27-2014 09:50 AM
extension cord rated for 20 amps? Martha Electrical - Systems, Generators, Batteries & Solar 15 02-28-2003 03:00 PM
