Old 04-14-2018, 07:36 AM   #1
chugchug's Avatar
2018 25' International
Belmont , California
15,000BTU AC, Honda 2000I, NO Easystart?
So. I received my Easystart yesterday, and before installation I decided to try the AC. We bought the trailer in December, so had no opportunity until now. It started fine on shore power, and then it started fine on just the generator. Yes, just the generator, no Easystart. From what I read. That shouldn't have worked, but it did.
I wonder. Does the 2018 model Dometic AC already has the Easystart, or similar, from the factory? Maybe it just works at sea level and will not work at altitude?
My generator is a few years old, but it had been used only lightly.
chugchug is offline   Reply With Quote
Old 04-14-2018, 08:03 AM   #2
2007 31' Classic
Gulf Breeze , Florida
Are you certain the compressor started, or just the fan? It is improbable that a Honda 2000 could produce enough amps to overcome the LRA of your AC.
trumpetguy is offline   Reply With Quote
Old 04-14-2018, 08:18 AM   #3
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
Here may be your answer - right from EasyStart:
"Air temperature also affects the air conditioner. Higher outside temperatures raise the refrigerant pressures causing a higher current draw. We have had some customers with Honda EU3000iS generators tell us that the generator will not start the air conditioner reliably when temperatures get hot. Most 4KW generators will start a single rooftop air conditioner reliably but that’s a lot of size and weight." https://www.microair.net/pages/easys...tallation-faqs
A small generator may start a larger A/C sometimes, depending on factors such as temperature, elevation, fan setting . . . Your generator may have just been lucky to hit the right combination of factors to start your A/C that time, but may not start it when you need it most - on a hot day!
I'm not sure if 2018's have easier starting A/Cs, but I believe you will want the EasyStart installed to reliably start your A/C from a smaller generator.
2017 Flying Cloud 25FB (Miles) 218 nights 30,171 miles
400W Solar, Blue Ox SwayPro, 16" Michelins
2017 Nissan Titan XD 5.0 Cummins Diesel 4x4
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 04-14-2018, 08:39 AM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
As previously stated, a 2000 watt generator will start an AC without an Easystart a lot of times. However, the strain you are putting on the compressor is damaging the AC unit and eventually it will fail prematurely.
Bob Martel
WBCCI# 5766
Old 04-14-2018, 09:01 AM   #5
chugchug's Avatar
I am certain the AC was running and cooling down the trailer, but it wasn't very hot outside, so probably easy conditions for the generator.
Old 04-14-2018, 09:38 AM   #6
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Easy start is a great addition anyways as it reduces wear and tear on the compressor. I have 2 of them (one for each AC). No regrets.
wulfraat is offline   Reply With Quote
Old 04-14-2018, 10:20 AM   #7
2016 28' International
Sioux Falls , SD
How long did it take you to install?
Any ďissuesĒ you came across?
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is online now   Reply With Quote
Old 04-14-2018, 10:26 AM   #8
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
Easy Start - Honda Eu2000i - 15,000 BTU A/C
I've had the same experience - my single A/C unit will start on my Honda Eu2000i however, you can definitely tell the compressor is struggling. I only did it once to convince myself I need to have Easy Starts installed on both my A/C units. I am taking our 2017 28' Serenity AS to JC in August for it's warranty work and I'll have them installed during that visit.
VaTravelers is offline   Reply With Quote
Old 04-14-2018, 10:26 AM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Easy to install, I don't remember how long, but maybe a hour at a leisurely pace.
My Honda is an older model and I can't run the converter at the same time as the AC. No big deal I just switch off the breaker to the converter.
2012 Dodge Durango Hemi/AWD
Old 04-14-2018, 10:38 AM   #10
Anna Maria , Florida
"Air temperature also affects the air conditioner. Higher outside temperatures raise the refrigerant pressures causing a higher current draw. We have had some customers with Honda EU3000iS generators tell us that the generator will not start the air conditioner reliably when temperatures get hot. Most 4KW generators will start a single rooftop air conditioner reliably but thatís a lot of size and weight." https://www.microair.net/pages/easys...tallation-faqs
I have no problem starting or running our A.C. with our Champion 3100 Inverter generator at any altitude. Have used it at 8000 ft no problem and no easy start.
franklyfrank is offline   Reply With Quote
Old 04-14-2018, 10:43 AM   #11
Glenn T's Avatar
2011 20' Flying Cloud
Lemont , Illinois
My AC started without the Easy Start, but the generator needed to be going full throttle. With the Easy Start, the generator can be in ECO mode.
The Easy Start ramps up the generator in ECO mode before it turns on the compressor. That saves gas and extends run time. Also, I can run the converter to charge the battery while the AC is on.
I always switch the refrigerator to run on propane with the AC running on the generator.
Glenn
Glenn T is offline   Reply With Quote
Old 04-14-2018, 11:26 AM   #12
2017 16' Sport
West Palm Beach , Florida
Lucky
It was a few variables, high temp outside and altitude will not run long on 2000w. You will need the easystart for summer and mountains for the compressor to total work. I have Sport 16, 11.500 BTU, this summer in KY going to MI for meet. 110 degrees at 8 pm on black parking lot, no easy start gen ran 5 min and off over load. Got to MI installed easy start no problems A/C runs well on 2000 watts.
truffies is offline   Reply With Quote
Old 04-14-2018, 01:51 PM   #13
wulfraat's Avatar
Less than 2 hours for both. I took my leisurely time - Iím a perfectionist
I bought the install kit for like $10 - it was worth it to have all the exact bits on hand
Old 04-14-2018, 01:58 PM   #14
wulfraat's Avatar
No doubt. Bed of my truck is setup for bikes so no room for a big genset so I enjoy the portability of a smaller unit.
Iím adding 600ah of lithium with hybrid inverter in 3 weeks - this will provide even more flexibility as Iíll be able to run my central unit off battery alone, or use the small genset to supplement battery to power a bunch of other things in the trailer while the ac is running.
A large genset is clearly a good choice, I just like the small little guy, so I am making up for lack of overall power output using other means (easy start + lithium).
Generally speaking I donít like running the genset at all given the noise it makes. But what ya gonna do when itís 95 degrees outside.
Can a EasyStart-Equiped AC really run from a Honda 2000? daleyocum Electrical - Systems, Generators, Batteries & Solar 17 12-02-2017 09:20 PM
Running your Dometic Penguin II on Honda 200 generator with EasyStart Driftin Di Boondocking 28 06-15-2017 02:29 PM
Honda 2000i vs. Honda 2000i Companion danandmimi Generators & Solar Power 33 09-13-2016 11:21 AM
Honda 3000is vs 2x Honda 2000i ILOVESALLY On The Road... 64 05-16-2014 10:13 AM
Honda 2000i companion + 2000i or just 2 2000i's??? socdiva Generators & Solar Power 5 10-27-2009 03:53 PM
