Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 04-15-2018, 06:22 PM   #21
Martee's Avatar
2017 25' Flying Cloud
Waco , Texas
Originally Posted by chugchug View Post
So. I received my Easystart yesterday, and before installation I decided to try the AC. We bought the trailer in December, so had no opportunity until now. It started fine on shore power, and then it started fine on just the generator. Yes, just the generator, no Easystart. From what I read. That shouldn't have worked, but it did.
I wonder. Does the 2018 model Dometic AC already has the Easystart, or similar, from the factory? Maybe it just works at sea level and will not work at altitude?
My generator is a few years old, but it had been used only lightly.
My 25FB Dometic AC failed to start with a Honda 2000i generator; but was successful with the Honda 2000i and 2000i companion in parallel operations. My Easy Start install took me just over 3 hrs and starts now with the Honda 2000i. 😊😊😊
Easy Start was definitely worth the effort and money. It should also prolong the life of the AC.
Martee is offline   Reply With Quote
Old 04-15-2018, 06:32 PM   #22
2016 28' International
Sioux Falls , SD
That’s a solid recommendation!
Thanks for sharing that.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 04-16-2018, 07:54 AM   #23
2007 23' Safari SE
Annandale , New Jersey
Originally Posted by callmedave View Post
At $500+ it's not cheap, but half the gen$$.
Dave, if youre referring to the Easy Start, the price direct from Micro-air is $299.
EasyStart
BTW, Honda just upped the 2000i to a 2200i, which I would expect to handle the load just fine.
Fred L is offline   Reply With Quote
Old 04-16-2018, 10:37 AM   #24
2018 27' International
carbondale , Colorado
Thank you, that was a great video. That was a coleman AC, i believe. Anyone have knowledge as to how the wiring differs on our Dometic AC and it is as easy as the video shows it? Also, I would like to install this on one of the two units I have in 27FB. Any opinions as to which of the two units would be preferable. Thanks for any replies.
capt_ron777 is offline   Reply With Quote
Old 04-16-2018, 10:47 AM   #25
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
15,000BTU AC, Honda 2000I, NO Easystart?
Here is the install guide for the penguin II AC unit.....
http://microair.net/main/products/ma...Penguin_II.pdf
I’ve done the install 3 times. It’s not hard.
wulfraat is offline   Reply With Quote
Old 04-16-2018, 10:47 AM   #26
That was agreat video. Thanks. Since that was a coleman, is there any video or instruction on our dometic units? Is wiring the same? Also, I want to put one of these in my 27FB, it has two ac's. Any opinions as to where it would best to place, LR or BR? Thanks for any replies.
Old 04-16-2018, 10:48 AM   #27
Oh, Oh. Looks like my question got put in twice. Sorry
Old 04-17-2018, 05:46 PM   #28
MMCMRET's Avatar
2021 25' Flying Cloud
Fredericktown , Ohio
I just had 1 installed. How long can I reasonable expect one to last camping 30-45 days a year in various conditions. Just trying to get a feel for the reliability of the Easy Start.
MMCMRET is offline   Reply With Quote
Old 04-17-2018, 10:19 PM   #29
wulfraat's Avatar
It’s a circuit board combined with a standard capacitor. Should last 10+ years. Worst cast the capacitor goes bad and you can replace that part for $30 or so
Can a EasyStart-Equiped AC really run from a Honda 2000? daleyocum Electrical - Systems, Generators, Batteries & Solar 17 12-02-2017 08:20 PM
Running your Dometic Penguin II on Honda 200 generator with EasyStart Driftin Di Boondocking 28 06-15-2017 01:29 PM
Honda 2000i vs. Honda 2000i Companion danandmimi Generators & Solar Power 33 09-13-2016 10:21 AM
Honda 3000is vs 2x Honda 2000i ILOVESALLY On The Road... 64 05-16-2014 09:13 AM
Honda 2000i companion + 2000i or just 2 2000i's??? socdiva Generators & Solar Power 5 10-27-2009 02:53 PM
