Old 04-14-2018, 02:00 PM   #15
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
Originally Posted by franklyfrank View Post
I have no problem starting or running our A.C. with our Champion 3100 Inverter generator at any altitude. Have used it at 8000 ft no problem and no easy start.
Looking at this generator... you have the 15,000 btu,?
HHPJ is offline   Reply With Quote
Old 04-14-2018, 08:50 PM   #16
2018 33' Classic
Newport , Pennsylvania
15000 btu a/c
it appears some Airstream owners want to tow big trailers with tiny tow vehicles and now they are trying to run AC with tiny Generators.
Using undersized generators will harm your AC units.
Earl
EarlM is offline   Reply With Quote
Old 04-14-2018, 09:57 PM   #17
2007 23' Safari SE
Annandale , New Jersey
A good reference .
Appears to be a very simple to install.
Its also some good info vs the hard start that many of the naysayers are possibly referring to ?
Fred L is offline   Reply With Quote
Old 04-15-2018, 09:36 AM   #18
Anna Maria , Florida
Yes I do. 30' Classic.
I start the generator let it spool up and turn on the AC. It runs the 15,000 btu and whatever else we need to use. Been using it for 3 years now. It weighs 80 lbs. I thought when I get to the point where I cant lift 80 LBS into the back of the truck I have no business being on the road with a 30' trailer either.
franklyfrank is offline   Reply With Quote
Old 04-15-2018, 04:40 PM   #19
callmedave's Avatar
2013 28' Flying Cloud
Cohasset , Massachusetts
Images: 14
Video
Originally Posted by Fred L View Post
A good reference .
Thanks for the link to the Easy Start install video - very helpful!
Wish I knew about this before dropping another $1000 on our second EU2000 generator. At $500+ it's not cheap, but half the gen$$.
Wallace: 2013 GMC Sierra 2500 D-Max
Gromit: 2013 Flying Cloud 28
callmedave is offline   Reply With Quote
Old 04-15-2018, 05:26 PM   #20
chugchug's Avatar
2018 25' International
Belmont , California
Thanks for all the replys.
I installed the Easystart today and ran the 5 training starts on shore power and then started it on the generator. The main difference I can see is that without the Easystart the system goes into full power as soon as the AC fan comes on. With the Easystart it takes about 20 seconds from the moment the fan come on to full powder. And it goes it in 3 stages: 3 amp at first, 5-6 amp next and then 13 amp. I suppose that is what the Easystart suppose to do. The slow start also allows the generator to run in ECO mode. Anyway, the next test will be when the temp gets into the 90's.
chugchug is offline   Reply With Quote
Old 04-15-2018, 07:22 PM   #21
Martee's Avatar
Waco , Texas
Originally Posted by chugchug View Post
So. I received my Easystart yesterday, and before installation I decided to try the AC. We bought the trailer in December, so had no opportunity until now. It started fine on shore power, and then it started fine on just the generator. Yes, just the generator, no Easystart. From what I read. That shouldn't have worked, but it did.
I wonder. Does the 2018 model Dometic AC already has the Easystart, or similar, from the factory? Maybe it just works at sea level and will not work at altitude?
My generator is a few years old, but it had been used only lightly.
My 25FB Dometic AC failed to start with a Honda 2000i generator; but was successful with the Honda 2000i and 2000i companion in parallel operations. My Easy Start install took me just over 3 hrs and starts now with the Honda 2000i. 😊😊😊
Easy Start was definitely worth the effort and money. It should also prolong the life of the AC.
Martee is offline   Reply With Quote
Old 04-15-2018, 07:32 PM   #22
2016 28' International
Sioux Falls , SD
Thatís a solid recommendation!
Thanks for sharing that.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 04-16-2018, 08:54 AM   #23
2007 23' Safari SE
Dave, if youre referring to the Easy Start, the price direct from Micro-air is $299.
EasyStart
BTW, Honda just upped the 2000i to a 2200i, which I would expect to handle the load just fine.
Old 04-16-2018, 11:37 AM   #24
2018 27' International
carbondale , Colorado
Thank you, that was a great video. That was a coleman AC, i believe. Anyone have knowledge as to how the wiring differs on our Dometic AC and it is as easy as the video shows it? Also, I would like to install this on one of the two units I have in 27FB. Any opinions as to which of the two units would be preferable. Thanks for any replies.
capt_ron777 is offline   Reply With Quote
Old 04-16-2018, 11:47 AM   #25
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
15,000BTU AC, Honda 2000I, NO Easystart?
Here is the install guide for the penguin II AC unit.....
http://microair.net/main/products/ma...Penguin_II.pdf
Iíve done the install 3 times. Itís not hard.
wulfraat is offline   Reply With Quote
Old 04-16-2018, 11:47 AM   #26
That was agreat video. Thanks. Since that was a coleman, is there any video or instruction on our dometic units? Is wiring the same? Also, I want to put one of these in my 27FB, it has two ac's. Any opinions as to where it would best to place, LR or BR? Thanks for any replies.
Old 04-16-2018, 11:48 AM   #27
Oh, Oh. Looks like my question got put in twice. Sorry
Old 04-17-2018, 06:46 PM   #28
2017 28' Flying Cloud
Fredericktown , Ohio
I just had 1 installed. How long can I reasonable expect one to last camping 30-45 days a year in various conditions. Just trying to get a feel for the reliability of the Easy Start.
MMCMRET is offline   Reply With Quote
Can a EasyStart-Equiped AC really run from a Honda 2000? daleyocum Electrical - Systems, Generators, Batteries & Solar 17 12-02-2017 09:20 PM
Running your Dometic Penguin II on Honda 200 generator with EasyStart Driftin Di Boondocking 28 06-15-2017 02:29 PM
Honda 2000i vs. Honda 2000i Companion danandmimi Generators & Solar Power 33 09-13-2016 11:21 AM
Honda 3000is vs 2x Honda 2000i ILOVESALLY On The Road... 64 05-16-2014 10:13 AM
Honda 2000i companion + 2000i or just 2 2000i's??? socdiva Generators & Solar Power 5 10-27-2009 03:53 PM
