Old 04-13-2017, 03:34 PM   #1
2010 27' FB Classic
N/A , Texas
15,000btu a/c, easy start, what generator
I have a Dometic 15,000 btu a/c unit that I want to run off of a generator.
I have a easy start 364 soft start on order and now I'm thinking about being able to step down a size in generators. I currently use a Yamaha 3000 and it has plenty of power to spare. I am considering a Yamaha 2400 once I install the easy start in my A/c unit to save space and lessen the weight in my TV.
Should I also consider the Honda or Yamaha 2000 or, is that a little too small to run the big a/c unit (say at least 8 hours/day) even with the easy start?
What do you think?
Old 04-13-2017, 03:36 PM   #2
2016 25' International
Deerfield , Massachusetts
It will run on the 2000.
thiel is offline   Reply With Quote
Old 04-13-2017, 03:50 PM   #3
2007 28' International CCD
Gulf Breeze , Florida
The issue is in startup ..not running. The Easy Start solves this and a Honda 2000 runs my Dometic 15000 just fine. Even on propane.
trumpetguy is offline   Reply With Quote
Old 04-13-2017, 05:01 PM   #4
2016 22' Sport
Clinton , Montana
Could you explain how you got the Easy Start installed? Was it at a dealer, a AC Heating specialist etc.? I asked my dealer about the Easy Start product and they were "turning themselves inside out"....trying to figure out what it was. Those that I spoke with had never "heard of one". Found that very odd since there is quite a few vids on YouTube explaining the tech behind the product and if necessary how a "competent DIY" person could install such.
Rpatrick16 is offline   Reply With Quote
Old 04-13-2017, 05:20 PM   #5
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
RV sales and service places typically just want to replace an AC unit that's not working these days. New ones aren't designed to be serviceable, so beyond a couple of standard issues there's no reason for them to have much AC expertise.
David
DKB_SATX is online now   Reply With Quote
Old 04-13-2017, 08:47 PM   #6
I installed it myself. Took about an hour and I am not knowledgeable about these things!
Old 04-13-2017, 09:04 PM   #7
wulfraat's Avatar
2008 25' International
Broomfield , Colorado
Get a Honda or Yamaha 2000. Either one will run your AC and @ just ~45lbs your back will thank you!
wulfraat is offline   Reply With Quote
Old 04-14-2017, 07:07 AM   #8
Easy Start provides a step by step instruction sheet. The hardest part was getting onto the roof without denting the metal. You can do it.
Old 04-14-2017, 08:18 AM   #9
2010 27' FB Classic
N/A , Texas
Thanks all.
You've been very helpful.
Now I can shop for a small gen and reduce the weight in my truck and gain some extra space for other stuff.
Old 04-14-2017, 09:14 AM   #10
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Originally Posted by Bluto View Post
Thanks all.
Just a couple of caveats that may or may not apply to your situation.
Be aware that if you convert your genny to run on propane you need to de-rate it by 18%. Also, you lose about 3% of the rated capacity for every 1,000 feet you go above sea level. So if you run your genny on propane (as we do) and camp at altitude (as we do) you would be surprised how quickly your 2000 watt generator becomes a 1200 to 1300 watt generator!
Bob Martel
WBCCI# 5766
Old 04-14-2017, 09:27 AM   #11
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I've personally tested both the Honda and Yamaha 2000's successfully on my 15,000 Dometic AC modified with the easy start.
Understand though, that's about all those small generators can handle at once. So make sure the fridge is running on propane, the water heater off or on propane, and no microwave use at all.
I also heard that if your trailer batteries are discharged the converter may siphon off too much power dealing with that, and also have enough left over to run the AC too. However I've not confirmed this.
kscherzi is offline   Reply With Quote
Old 04-14-2017, 10:53 AM   #12
2004 25' Safari
1968 17' Caravel
Fountain Valley , California
Relative to the last post, I have the Yamaha 2800 Inverter gen (about 8 years old), and no soft start. So, if the batteries are partially discharged I open the breaker to the converter, then start the air conditioner, then re-close the breaker. Everything runs fine then. (unless I decide to try and run the microwave at the same time as the Air conditioner).
WindyJim is offline   Reply With Quote
Old 04-14-2017, 11:28 AM   #13
This is close but not quite right. LP propane derates it by about 2%. Natural gas derates it by more like 15%.
Old 04-14-2017, 12:37 PM   #14
Houston , Texas
What about a good hard start, 15k a/c, and a 2000 genset. This is a question not a suggestion. Anyone tried this? I'm trying to decide on a course of action myself. Plusses are cost. What are the minuses even if it will work.
Will a 3K class genset start a a 15k a/c. You know what they say about cubic inches, could be the same about watts.
Asherstanton is offline   Reply With Quote
AC Upgrade to 15,000BTU pappy19 Furnaces, Heaters, Fireplaces & Air Conditioning 19 03-11-2016 02:20 PM
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 20 04-19-2010 11:14 AM
