Old 04-14-2017, 02:10 PM   #15
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The newer Penguins come with a good hard start, but some find they can start on a 2k genny, others not. The Easy Start is a sure thing for a 2k genny.
Larry
lsbrodsky is offline   Reply With Quote
Old 04-14-2017, 02:16 PM   #16
2000 30' Excella
Greeneville , Tennessee
Westinghouse builds a good looking gentleman, 2400. Lightweight and ample output. It is and inverter/converter to protect your electronics. The price is great, do some looking.
jimfa440 is offline   Reply With Quote
Old 04-14-2017, 02:24 PM   #17
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
I have used Honda 2000 in altitude (Colorado) with propane, nonissue. Works fine. I agree with Theil, it's derated by 2-3% max on propane. Natural gas is where you see a big derate.
Troutboy
Troutboy is offline   Reply With Quote
Old 04-14-2017, 03:28 PM   #18
2000 30' Excella
2014 30' Classic
Princeton , Iowa
Generators
I would have 2 Honda 2000 or one Honda 3000. I have two air conditioners so I run 2 Honda 3000. I built a ramp to load them in my pickup. Works wonderful.
larryglarson is offline   Reply With Quote
Old 04-14-2017, 04:56 PM   #19
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
The 200 watt Honda is a light weight generator , these weren't built to run a 15500 but ac 8 hrs a day....it will be short lived....
Old 04-14-2017, 06:17 PM   #20
lewster's Avatar
Naples, FL , Hood River, OR
Running a 15K A/C unit is not the problem.......STARTING IS and the Easy Start alleviates this issue completely.
Typical full load amps of a Dometic 15K BTU RV roof A/C unit is in the 14-16 amp range.....well within the stated operational characteristic of either a Honda or Yamaha 2000 watt generator.
The Easy Start reduces the transient load of compressor initiation to well under 20 amps (more in the 16-18 amp range), which is also well within the initial load capacities of these units.
I really don't see how using a properly rated generator within it's stated operating limits will negatively effect the longevity of the unit. In a year from now....we'll see if anyone has burnt them out (which I seriously doubt!).
....and by the way.......if one looks at the U Tube video that Micro Air has posted on one of the threads on this Forum, you will see that the additional a 'hard start kit' has NO EFFECT on the locked rotor amp draw of a Dometic roof A/C. Dometic already includes a hard start capacitor and PTCR in every unit they make and Matteo's video is proof that an additional hard start kit has no effect!. Check it out yourself!!
Old 04-14-2017, 10:15 PM   #21
Troutboy's Avatar
Parker , Colorado
I agree with Lewster, that using the 2000W for this application will not wear out the generator sooner. A generator doesn't care what the load is from, as long as it's within the operating specs, which as he mentions above this is. No different IMO if you ran enough smaller loads to equal this load.
As long as the generator is properly maintained and not run outside of spec, it will run as designed, regardless if the load is a generator or coffee pot.
Troutboy
Old 04-14-2017, 11:06 PM   #22
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
If you check with US Carburation. They will state that propane use in their propane conversions are not an issue. No derating required. I have had a Yamaha 3000 eisb for 10 years with no operational problems.
guskmg
Old 04-16-2017, 11:30 AM   #23
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
On a long hot day, the little 2000 ,actually 1600 , will be overworked, not mine
Old 04-16-2017, 11:43 AM   #24
Mollysdad's Avatar
Originally Posted by Bluto View Post
I have a Dometic 15,000 btu a/c unit that I want to run off of a generator.
I currently use a Yamaha 3000 and it has plenty of power to spare. I am considering a Yamaha 2400 once I install the easy start in my A/c unit to save space and lessen the weight in my TV.
I understood you to say your Yamaha 3000 starts and runs the 15000BTU A/C just fine? Power to spare?
I'm asking because I'm shopping for a generator in that range. I think the Yamaha EF3000iS is rated at 2800 w. running. They also make a EF3000isB, that has a boost for a little bit for starting.
It would be good to know that a 3000 isn't limited to the 13,500 A/C.
Old 04-16-2017, 12:25 PM   #25
2010 27' FB Classic
N/A , Texas
I have the 3000 with the boost. It works well as I mentioned on a 15,000 a/c unit plus other stuff we use in the trailer. What those other things are exactly I don't know as I don't really think about it but, I never had it shut me down.
I would not try to run the microwave and A/C at the same time while on gennie power. There are lists out there that can tell you the amp draw of each appliance you may want to use in the trailer then use the gennie accordingly.
Old 04-17-2017, 01:25 AM   #26
2010 27' FB Classic
N/A , Texas
Correction:
The above post should read that I have not tried to run both the a/c and microwave at the same time on the Yamaha 3000 w/boost generator. Usually if I'm on gennie power I'm pretty frugal with electricity anyway!
Old 04-21-2017, 01:21 AM   #27
Sam and her wheelman Zeke
upnorththree's Avatar
2014 25' FB Flying Cloud
Northern , Illinois
Briggs and Stratton???
Why do I read any and all comments about the Honda and Yamaha? Seriously.
I'm in the market for ANY fine generator but, I would prefer a small one and all I see on this forum is a lovefest over Honda and Yamaha.
Aren't any others worthy? Generac? Briggs?
Any advice is welcome.
Thanks much.
Popeye, Olive Oil, Sam, and Zeke riden' on 20's.
2015 RAM Laramie Eco-Diesel 4x4 crew cab w/RAM box
upnorththree is offline   Reply With Quote
Old 04-21-2017, 06:46 AM   #28
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
I went with the Honda. I didn't test them all. I bought it online from a generator site. It's very quiet compared to other generators I hear in campgrounds. Engine noises bother me when camping. It's also very easy to handle, meaning light weight. I've had good luck with other small Honda engines. I would imagine the Yamaha, Briggs, and others are fine. I'm going with the easy start on my AC, so the 2000 is all I'll ever need. Just debating now if I want to convert to propane.
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Running your Dometic Penguin II on Honda 200 generator with EasyStart Driftin Di Boondocking 28 06-15-2017 02:29 PM
13500 BTU vs. 15000 BTU Eddie25 Furnaces, Heaters, Fireplaces & Air Conditioning 14 12-21-2013 12:50 AM
HOT IN TEXAS!!!! Upgrade a 13,000 BTU to a 15,000 BTU? Does it help? bowhead13 Furnaces, Heaters, Fireplaces & Air Conditioning 47 07-19-2013 01:02 PM
Generator for 11,000 BTU AC boutdoors Generators & Solar Power 12 08-25-2011 06:56 PM
15K BTU Brisk Air vs. 15K BTU Penguin adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-23-2011 11:32 AM
