Old 08-18-2013, 07:00 PM   #1
1966 22' Safari
2007 27' Classic FB
Quartz Hill , California
Question 13,500 BTU wont work with 2 Honda 2000 generators
Hello,
I am an avid Airstreamer. We own an old 1966 airstream and now a 2007 airstream. The new(new to us) one has a Dometic 13,500 roof air conditioning unit so today, I went and spent around $2000 for the Honda 2000 with its companion and came home with full excitement to try it. It ran the unit for approximately 5 minutes until the AC unit became fully running with cold air, and then it ran another 5 minutes. During the latter 5 minutes the generators made alot of noise and it was not consistent, kind of like it was running intermittently, so we turned them off for a minute. We then restarted them, and tried again, this time, maybe a total of 15 minutes went by when both generators load dropped and our AC turned off. We looked at both generators and both said OVERLOAD.
I was told that using both Honda Generators piggyback would be enough to run this AC unit. By the way, nothing else at all was running, so now I am so confused what to do.
I have MS and I need this AC to work when it's too hot and I saved just to get both these and liked the thought they were both less than 50 pounds, making it easy for myself or my husband to use them.
HELP PLEASE.
Any reasons you may have why this isn't working?
Any help would be appreciated.
Jonnagyp is offline   Reply With Quote
Old 08-18-2013, 08:16 PM   #2
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
Have you tried turning off the "Eco Throttle" switch on your generators? I need to turn off the Eco Throttle switches on mine to keep the generators from sometimes going into overload when the air conditioner compressor cycles on.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 08-18-2013, 08:28 PM   #3
r carl's Avatar
Lin , Ne
Those Honda's are more than enough to run a 15,000 ac unit.
Old 08-18-2013, 08:33 PM   #4
Central , Mississippi
I had the same problem, it turned out my starting cap was marginal. I changed to an easy start kit and now the dual 2000's have no problem kicking the 13500 off.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-18-2013, 08:56 PM   #5
1966 22' Safari
2007 27' Classic FB
Eco Throttles were OFF
Yep, both generators had the Eco Throttle off.
Old 08-18-2013, 09:13 PM   #6
1967 24' Tradewind
Telluride , Colorado
I would get a kiill-a-watt (google it)and put it on the ac side, turn on the ac and see what it was pulling. Then I would know if it was the ac unit or the gen set. Its a start.
purdiferis is offline   Reply With Quote
Old 08-18-2013, 09:19 PM   #7
1966 22' Safari
2007 27' Classic FB
Thanks. AC unit has rarely been used but have all the paperwork and know the exact details of the unit. 13,500 BTUs, is the deal.
Old 08-18-2013, 10:20 PM   #8
Originally Posted by Jonnagyp View Post
Hello,
HELP PLEASE.
It's not true that "nothing else" was running.
The Univolt "always" runs.
Depending on the condition of the batterie, the Univolt can draw 6 to 7 amps itself.
Old 08-19-2013, 05:26 AM   #9
Gainesville , Florida
Does the AC unit work on shore power? 30amp/120volt. Jim
Old 08-19-2013, 07:46 AM   #10
1966 22' Safari
2007 27' Classic FB
Yes, the AC works great on shore power and I guess what I mean by nothing was running - we made all lights, and anything and everything turn off, so only the AC was on. Today I will check the watts so I can report back to you.
Can it be that ONE of the generators is bad? They were brand new out of the box, but ONE, the main one, not the companion was the one that was making noise by revving up and down when it was under load.
We have a friend who has another Honda 2000 so we are going to borrow it and use his with our companion to see if there is any change in performance.
I appreciate you answers and any new answer gives me hope.
Old 08-19-2013, 08:19 AM   #11
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have been using 2 Honda 2000's for the last 5 years to run the 13,500 btu air conditioner on our 2005 Safari 25FB. The two Hondas have been able to run the whole trailer on most occasions. These gensets have been able to do the job with the air conditioner, refrigerator, converter, and lights all running.
The only times that I have run into any problems with the generators is at high altitudes. While camping in the Bighorn National Forest at about 9,000 feet, the generators just don't put out like they do at sea level. The gensets will run the air conditioner, but I have to cut off everything else, including putting the refrigerator over to gas.
Brian
SuEllyn & Brian McCabe
Old 08-19-2013, 08:59 AM   #12
2002 25' Safari
Images: 11
Are you using the Honda wire kit to connect the two generators in parallel? Are you connecting the "R" labeled wire to the right generator connector and the "L" labeled wire to the left generator connector on both generators? Are you plugging your 30 amp cord into the Companion generator?
Bud
Old 08-19-2013, 09:07 AM   #13
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
What is an "easy start kit"? Also, what is the "Univolt"?
TinCan
graysailor is offline   Reply With Quote
Old 08-19-2013, 09:08 AM   #14
1981 31' Excella II
New Market , Alabama
I can't imagine even needing an AC unit at 9000 ft. Try turning eveything off accept the AC and see if that helps. You can get a cheap AMP probe from Harbor Freight and that might tell you how much your total current draw is. You will need access to a hot wire to put the probe clamp around.
Perry
