Old 08-18-2011, 09:16 PM   #21
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Ok well a little design time now that the shell is back on the frame and the wind wont carry it away....
I am planning on using two of the IronRidge XRS rails per row with custom aluminum cross bars to limit the flex in the array.
There will be a street side row and a curb side row running the full length of the shell.
Rather than use the "L" mounting feet I am going to use an L extrusion mounted the length of the shell and then bolted into the XRS rail at multiple locations. This will dissipate any point load on the shell.
http://www.civicsolar.com/sites/defa...ail_System.pdf
I have used the heavy aluminum piano hinge before in creating tilt systems and this may be an option as well for a tilt on site system
ID:	138083   Click image for larger version
Darkspeed is offline   Reply With Quote
Old 08-19-2011, 03:52 AM   #22
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
I think I like the idea of flush mounting the extrusion rail. I'm assuming there aren't any issues of catching debris or trapping water.
UAPachyderm is offline   Reply With Quote
Old 08-19-2011, 07:57 AM   #23
Darkspeed's Avatar
1972 31' Sovereign
My biggest concern is not trapping any air.
I will have a lot of variable surface area moving down the road at 60mph. Don't want to turn it into a wing.
Old 08-19-2011, 09:00 PM   #24
Lewster installed a spoiler/air dam on the front edge of his ... but a fly behind Airstream might save you on tires. 
Old 08-19-2011, 10:00 PM   #25
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Braking, however, could get REALLY exciting!
David
DKB_SATX is online now   Reply With Quote
Old 08-19-2011, 11:00 PM   #26
tr0y's Avatar
Las Vegas , Nevada
I flat mounted mine with AL angle. Losing a 40 lb panel or four @70 really seems like a bad idea.
tr0y is offline   Reply With Quote
Old 08-19-2011, 11:41 PM   #27
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Moving down the highway straight line shouldn't be a problem - crosswinds and turbulence from semi-rigs & underpasses might give all the stops a good rattle though.
On a continuous rail like the IronRidge XRS I think a larger footprint bracket or reinforcing plate matching the shell rib would provide equal or better bracing and allow water to drain... and maybe a little Stuka dive bomber sound effect in a strong cross wind
Wondering about the piano hinge - will they exist on both sides or wobble adjust from the center or such?
For a small maintainer panel I'd love to pirate the television antenna pivot mechanism idea to put a radome (radar dome) type azimuth and elevation adjuster for a single 40 or 50 watt panel.... manual, not tracking (yet)
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Worth $2600 for the Airstream solar system? scubadog Generators & Solar Power 22 10-14-2012 10:35 AM
1998 Airstream Excella Classic 1000 34 FT LARGE Solar @ eBay Watch Airstreams on eBay 0 08-11-2011 09:30 PM
2011 Airstream Travel Trailer with Solar eBay Watch Airstreams on eBay 0 06-28-2011 02:20 PM
2011 Airstream Flying Cloud 20 foot-like New with SOLAR eBay Watch Airstreams on eBay 0 05-14-2011 05:50 PM
