Old 04-24-2016, 02:38 PM   #1
2013 25' Flying Cloud
Middleton , Idaho
1/4 or 3/8" hose for EU2000i on propane?
I recently installed a US Carb tri-fuel kit on my Honda EU2000i generator. Can I run the generator with a load (i.e. microwave) using a 1/4" hose that is 8' long, or do I need to get a 3/8" gas hose? I already have the 1/4" hose for a BBQ, and was hoping to also use it for the generator. I will be connecting it to the low pressure female fitting on the front of the trailer.
Thanks- Bob
Trailbob is offline   Reply With Quote
Old 04-24-2016, 02:57 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
My 3000 is set up to run low pressure propane on a 1/4 in line. That is there is a regulator at the tank reducing the tank pressure.
I have a 3/8 hose with quick disconnects to run it on natural gas household pressure. I have not used that hose yet and got it more for the match to the quick disconnect on the house. I would think your 1/4 hose would work for both fuels.
2004 Excursion 4x4
Old 04-25-2016, 08:46 PM   #3
Middleton , Idaho
Thanks HowieE. Sounds like it should work fine with the 1/4" line.
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
Propane Powered EU2000i? Pick Generators & Solar Power 8 04-09-2016 06:36 AM
Dual propane tap for 2 Honda EU2000i generators fred bartlet LP Gas, Piping, Tanks & Regulators 2 05-09-2010 12:31 PM
Propane Powered EU2000i Pick Generators & Solar Power 35 05-04-2010 03:21 PM
