Old 09-17-2010, 03:45 PM   #1
1975 31' Sovereign
Waterloo , Iowa
yellow wire in right rear light assembly.
In my right rear light assembly there is a yellow wire which I cant match up to anything. Does anyone know what this wire is for?
robertel is offline   Reply With Quote
Old 09-17-2010, 05:11 PM   #2
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Been told the right rear light is wired for rearview camera. Maybe that is what you have.
mhilley is offline   Reply With Quote
Old 09-17-2010, 05:24 PM   #3
x
XXXX , XXXX
No cameras on a 75. I don't have anything like that on mine. It might be a rewire by a PO. You should only have brown (turn & stop) green (running) and black (reverse).
wasagachris is offline   Reply With Quote
Old 09-17-2010, 05:35 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Options
License Plate???? Backup Lights????
Old 09-17-2010, 08:03 PM   #5
Splitrock's Avatar
Sioux Falls , South Dakota
Yellow was used for back up lights by Airstream for trailers made to sell in Canada according to my Service Manual. You might check that lead.
It's easy to test all the wires by only powering one wire at a time. I've replaced and repaired anything on my 12 volt system so far with a multi-meter, a small battery charger, a jumper light, and a 7-way tester for the towing connection. I'd go to the 7-way and power one wire at a time and see what it takes to make that yellow wire hot.
Gary
Old 09-17-2010, 10:01 PM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
I don't know whether your coach pre-dates the fiber-optic tailight monitor, but the thought that ran through my mind was - - could it be a fiber optic cable for the optional tail light monitor??
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 09-18-2010, 06:14 AM   #7
Splitrock's Avatar
Kevin
Good catch! My '76 has the fiber-optic feature. I can't remember the color of the cable though. I bet that's it.
Gary
Rear Running Light Wire snapped spat61 Airstream Motorhome Forums 0 06-12-2010 07:10 PM
Taillight wiring, where does yellow wire go bmklawt Lights - Interior & Exterior 3 03-17-2009 05:20 PM
Tail light assembly problems DanB Electrical - Systems, Generators, Batteries & Solar 1 05-03-2007 09:07 AM
Tail light red, green, yellow wires? PKelley Electrical - Systems, Generators, Batteries & Solar 2 06-08-2005 07:28 AM
Ceiling Light Assembly Sanders Lights - Interior & Exterior 2 10-11-2004 06:15 PM
