Old 11-17-2011, 06:18 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Wrong Umbilical Cord?
Are there more than 1 type of 7-pole umbilical cords? I bought one a long time ago for the Bambi II project & thought I got the right kind for my TV, but this one:
Bargman 7-Pole Round Connector w/ Hardware - Trailer End - 1' Long Bargman Wiring 54-67-525
doesn't stay in the outlet. The one that's on my Sovereign (after looking at it more closely tonight) looks more like this:
Hoppy 7-Way Molded Connectors with 8-Ft. Cable, Model# 20146 | Trailer Lighting | Northern Tool + Equipment
Are they not compatible? Anyone want to buy a cheap umbilical cord if they're not???!!!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 11-17-2011, 06:20 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Becky, they both should fit your truck's plug. If it falls out, maybe the spring that holds the flap down to keep the plug in is bad. One plug may fit a little more snugly, which is why it is staying in.
Old 11-17-2011, 06:34 PM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Consider zip-tieing, the plastic plugs do tend to separate and grind away.
Name:	06 BURB SHAKEDOWN TRIP 018.jpg
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-17-2011, 07:58 PM   #4
Becky B.'s Avatar
1964 17' Bambi II
The DH just went out again & tried it in his truck (which is also compatible with the Sovereign) It doesn't fit there either. I guess I'm gonna have to get a different one. What a pain!
Becky
1964 Bambi II
1988 Avion 32S
Old 11-18-2011, 02:01 PM   #5
Becky B.'s Avatar
1964 17' Bambi II
So, today I went to the local RV store with my pigtail in tow. The guy takes it & strolls over to my TV and plugs it right in. Puts the cover down, tugs on it, and it stays in. Why, tell me, does my DH not listen to my friends here on the forums????!!!! I'm biting my tongue. Then he said the power wasn't working on my truck cause there was no power on the cord. I pulled my truck over to the Sovereign... LIGHTS! Not my TV's problem. So, I took the cord, stuffed it in the plug, put the cover down (like everyone here said & the RV guy said) and VIOLA!! It has power! Still biting my tongue. So guys, thanks for your help. My DH is outside right now connecting the pigtail to the Bambi II. Maybe later we'll have some lights! Electric isn't my forte' so I must be kind to the DH while he helps me out!
Becky
1964 Bambi II
1988 Avion 32S
Old 11-18-2011, 03:01 PM   #6
Southwestern , Ohio
So, how come you got the impression it "didn't fit"? Just not pushing hard enough?
Incidentally, it's a good idea to put some silicone dielectric grease (available from auto parts stores) on both halves of the plug. It makes it go in easier and helps prevent corrosion. As you have seen, a tab on the socket cover hooks over the rib on the plug and holds it in place.
Nuvite-F is offline   Reply With Quote
Old 11-18-2011, 03:55 PM   #7
Becky,
Please be kind to the DH, we do come in handy at times.
Originally Posted by Nuvite-F View Post
So, how come you got the impression it "didn't fit"? Just not pushing hard enough?.......... As you have seen, a tab on the socket cover hooks over the rib on the plug and holds it in place.
kind'a....but don't count on it. I use zip-ties, but a wrap or two of electrical tape will also hold the cover on the "lock" tab. Have had two plugs ground down to the nub's.
Dielectric grease, good to have in your tool kit.
PFC
RLC
Old 11-18-2011, 05:30 PM   #8
dirigible25's Avatar
1997 25' Safari
Yakima , Washington
7 way pole and 7 way blade
Looks like you got it figured out. At first I thought you had a 7 way blade on one unit and a 7 way pole on the other, but now that you have it working you are good to go.
dirigible25 is offline   Reply With Quote
Old 11-18-2011, 07:38 PM   #9
Becky B.'s Avatar
1964 17' Bambi II
Because when the cover isn't snapped over the edge of the plug, it pretty much falls out on its own. The one on the Sovereign is really tight without the cover being snapped over it.
Becky
1964 Bambi II
1988 Avion 32S
Old 11-18-2011, 07:42 PM   #10
Becky B.'s Avatar
1964 17' Bambi II
[QUOTE=ROBERT CROSS;1073945]Becky,
He is very handy, and I do try to be kind. We've been married 30 years, so we must do something right! Sometimes, tho, I just need to walk away! (as I'm sure most have to do sometimes!)
Becky
1964 Bambi II
1988 Avion 32S
Old 11-18-2011, 07:43 PM   #11
Becky B.'s Avatar
1964 17' Bambi II
And finally, I will be using Zip ties & dielectric grease! Thanks all!
Becky
1964 Bambi II
1988 Avion 32S
Old 11-18-2011, 08:17 PM   #12
Well Preserved
1993 21' Sovereign
Becky, now you probably know why this thing is sometimes called an imbecile cord...
Old 11-19-2011, 05:56 AM   #13
Kind=Time....Have Fun.
PFC
RLC
Electric Power Cord crazeevw Classic Motorhomes 13 12-21-2014 10:32 PM
30 amp cord to 50 amp outlet. urnmor Batteries, Univolts, Converters & Inverters 20 10-21-2011 12:55 PM
Simple Q: 30 amp RV cord to 15 amp wall unit.. Shmeter Electrical - Systems, Generators, Batteries & Solar 2 07-17-2011 07:55 AM
7 Way Trailer Cord aname4me Electrical - Systems, Generators, Batteries & Solar 6 03-09-2011 11:20 AM
Power cord length-recommendations? SilverHoot Electrical - Systems, Generators, Batteries & Solar 17 01-23-2011 02:39 PM
