Old 09-09-2010, 05:00 AM   #1
1975 31' Sovereign
Waterloo , Iowa
Wiring to rear turn/brake lights
I removed the rear light assembly and now can't remember the correct connection of the wires to this assembly.
Any assistance appreciated.
robertel is offline   Reply With Quote
Old 09-09-2010, 06:15 AM   #2
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
The first way is by trial and error. Hook up the TV and TT - and work thru the wiring one at a time. Or, you might just look at the wiring and hook up the same color wire from the trailer to the light. Unless you changed the wiring - then it is back to the first way. IMHO
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 09-09-2010, 06:31 AM   #3
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
A small test light and a note pad
kennethowens is offline   Reply With Quote
Old 09-09-2010, 07:12 AM   #4
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by robertel View Post
I removed the rear light assembly and now can't remember the correct connection of the wires to this assembly.Any assistance appreciated.
These diagrams are for a '78 - might be similar.
Double click on the images for an expanded view.
Included here is a colored schematic of the interior wiring - it's nothing to do with the running lights, but may be of help later.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 09-09-2010, 08:00 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you just remove the tail light assembly, there shouldn't be any need to check all of the trailer wiring. Does the assembly have more than one bulb? Perhaps a bulb for back up lights. Most have a dual filament bulb. If you only have the tail light assembly with one bulb, it has a dual filament. They are offset within the bulb. The filament closest to the base of the bulb is the brake light and is much brighter when on than the other filament. Go ahead and connect the wires coming out of the trailer to the new fixture, make sure the fixture is mounted so it has a ground. Then turn on the headlights in the TV, if the filament furthest from the base is lit, you got it right, if not, reverse the two wires and test it again. Once it is right, be sure to test the brake light. Good Luck
Old 08-05-2015, 02:34 PM   #6
Mission , Texas
Ditto ...
The original light has two wires as does the trailer.
Sadly the replacement light only has one wire.
So by trial and error, either it will work or not.
nrgtrakr is offline   Reply With Quote
Old 08-05-2015, 02:59 PM   #7
Mission , Texas
Reading the schematics encountered via an external search, green should be positive (12vdc) and white should be ground.
Sadly BOTH multimeters are in Mexico - ooops!
I'll return later after installing the new license plate light and subsequent smoke test.
Why there wasn't a forum like this when I was a teenager working on my 41 Ford pickup is beyond me. Oh yeah, Al Gore hadn't invented the internet yet.
Old 08-05-2015, 05:54 PM   #8
Mission , Texas
Yep ...
I can still read schematics as well as fix stuff.
Thanks AS Forum!
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
LED Brake/Turn Lights kamadeca Lights - Interior & Exterior 12 05-27-2010 02:05 PM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
Brake/Turn Light Wiring Question (late 70's) DPeakMD Electrical - Systems, Generators, Batteries & Solar 3 07-14-2004 12:46 PM
