Wiring Single Bulb Tail Lights to 7 Pin
I'm in the process of wiring the tail lights on our rig--old single bulb Bargman 98s. So the brake/turn and running light wires both need to be joined to the socket's hot wire, yes? Well, I did this and, when testing with a 6v battery all the lights (running, LT/Brake, RT/Brake, etc.) come on together regardless of which wire I test. Looks like the running light wire is completing the circuit in all cases. I've got the ground wire running to the negative terminal of the test battery for now. What am I missing/doing wrong?
