Old 08-28-2014, 08:11 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Wiring a Signal-Stat for bathroom light???
Our Bambi II has a automobile Signal-Stat stop/turn signal light with a clear lens for the bathroom light fixture. A good idea on Airstream's part for a fairly weatherproof light fixture in a wet bath setting.
I cannot figure out how to wire it in properly to my 12 volt circuit. It has two wires (red and brown) leading to the isolated bottom connector for the light bulb (connecting to the terminals on the bottom of the light bulb) and a green wire soldered to the outside of the light socket. There is also a toggle switch wired in to operate it.
Which wire/s should go to the positive and which wire/s should go to the common? I have tried a few combinations and keep getting shorts.
Any help would be appreciated. Thanks so much!
ID:	220126   Click image for larger version
ID:	220128   Click image for larger version
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 08-28-2014, 08:16 PM   #2
r carl's Avatar
Lin , Ne
The green is the common. (ground)
Signal-stat 3101 Keyholeren Electrical - Systems, Generators, Batteries & Solar 18 07-15-2009 06:39 AM
Signal Stat 9007 driftwood Electrical - Systems, Generators, Batteries & Solar 6 10-06-2003 06:57 PM
