Old 06-28-2011, 11:54 AM   #1
1972 29' Ambassador
Fayetteville , West Virginia
Wire from truck to 'stream. Where to get?
So I have towed the old girl three times now with no lights, (very short distances, but still very unsafe, I know, I know) and I just figured out that the little white socket on the front is the plug-in point for a cable to run from the hitch socket on the truck to the camper. Where can I purchase this cable?
TJ
W.V. Stream is offline   Reply With Quote
Old 06-28-2011, 11:58 AM   #2
1973 25' Tradewind
1964 19' Globetrotter
Centerville , Utah
Inland RV or Vintage Trailer supply are great resources.
tclay
Stormy Weather is offline   Reply With Quote
Old 06-28-2011, 12:49 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
My antique trailer had a 7-way connection box on the trailer. I just ordered a new umbilical cord with a molded 7-way plug on one end from the local trailer guy that services horse trailers as his main business.
Old 06-29-2011, 04:42 AM   #4
1972 29' Ambassador
What is the proper name for the cable?
Old 06-29-2011, 05:03 AM   #5
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink Toe vehicle wire....
I call it "the wire from the toe vehicle to the trailer"....
the real answer may be here....trailer wiring - Google Search
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 06-29-2011, 05:56 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It's called an umbilical cable.
Old 06-29-2011, 11:57 AM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
make your own umbilical cord
You really need to get those brakes working! All those hills in WV Do you have a brake controller?
I camped up in your area last fall, in a national forest just west of I-77 near Charleston. Way back up in a holler between two mountains, no one around, near some old natural gas wells. Only saw one ranger who collected the fee. I loved it!
That umbilical cord you need may not be easy to find factory made. You can make it yourself, fairly easy. Just go to your local RV or electric supply for plugs and wire. Tractor supply or uhaul may have this too. Get a connector plug to fit each receptacle. The one on the tow vehicle will most likely be different from the one on the trailer. There are flat pin and round pin and a variety of sizes, so make a sketch or take pictures with you when you go get them. Diameter of the plug and pin type is what you will need to know.
A word of caution: When working on the trailer end, the plug housing on the trailer may be made of magnesium. This can catch on fire if you grind or drill it, yes this metal will burn like a torch. Water will not put out this type of fire. There are threads on this forum regarding this, use the "search" function to find more info.
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 10:02 AM
1988 Running Light Exposed Wire vhariable Lights - Interior & Exterior 2 06-25-2011 08:56 PM
Where does this heavy black wire go? malconium Electrical - Systems, Generators, Batteries & Solar 3 05-31-2011 01:07 PM
One Wire Running Lights---Effects on Grounding tinbender Lights - Interior & Exterior 7 04-18-2011 07:22 AM
Burnt wire on my univolt MonaxLisa Batteries, Univolts, Converters & Inverters 11 03-23-2011 12:31 PM
