Old 10-16-2014, 06:06 PM   #1
LivLoveLaugh's Avatar
2012 30' International
South Western , Pennsylvania
Why not LED lights in the stove hood?
We have a 2012 CCD Internatioal. The unit has LED lighting through out the trailer except the two lights above the stove in the range hood, they are halogen lights .
Is there a reason for not using LED above the stove?
I think I would like to replace them with LEDs but I would want to know why Airsteam used or just left the halogen lights above the stove.
Sometimes I pretent to be Normal....
but it gets boring, so I go back to being me
LivLoveLaugh is offline   Reply With Quote
Old 10-16-2014, 06:09 PM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Not sure why AS would have left those lights as halogen, possibly because they are typically used less than some of the others. LED replacements are available at LED4RV.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-16-2014, 06:14 PM   #3
2011 25' FB Flying Cloud
Anywhere & , Everywhere
The hood comes from the manufacturer with halogen lights. Why would Airstream go to the expense of replacing them? They are easy to replace - I've done mine - and "bulbs" are available from many sources including LED4RV.
Al - K4GLU is offline   Reply With Quote
Old 10-16-2014, 06:32 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I replaced my oven light with LED unit from LED4RV. Worth every penny. Makes a nice noninvasive light. to leave on.
MICHAEL
Old 10-16-2014, 06:39 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I replaced my range hood light with LEDs from Dan at LED4RV. First I got the warm white, which were not quite bright enough for me. Then I changed to LEDs over the range and the sink to bright white.
Alan
Old 10-16-2014, 06:46 PM   #6
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
I just replaced ours with LED. It literally takes about 2 minutes. Just be careful not to drop the lens when you take the light fixture out. The pins in the LED's fit right in where the bulbs come out. Out-of-Doors-Mart also has the LED replacements.
Silverbee is offline   Reply With Quote
Old 10-16-2014, 10:34 PM   #7
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
I installed LEDs in our hood as well from our local RV shop, Palm RV in La Habra
subfan1 is offline   Reply With Quote
Old 10-17-2014, 12:22 AM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my range hood has a regular bulb in it, possibly an 1141? It still works after ten years. It wasn't really used much until lately. We have been using this light as a night light.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-17-2014, 07:19 AM   #9
Thanks all for the replies.
I thought maybe there was a issue with heat from the stove that would affect the LEDs and that's why AS left in the halogen lights.
Thanks again!!
Old 10-17-2014, 11:20 AM   #10
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Changed out my hood light with led but the greatest improvement was relocating it for actually lighting the area not the aisle in front of the stove. It will make an excellent low power light without glare in the evening. AS liked visible light bulbs, we prefer indirect.
I think the heat problem would be more in the stove that others are talking about.
Old 10-17-2014, 06:28 PM   #11
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
As others have posted....pull out those power hungry and WAYYYY too hot halogen's from your Baraldi and put in the LED's. The glass lenses unclip and the bulbs slide out....with the LED's sliding right in. They put out plenty of light and don't generate the heat that you don't want anyway.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 10-19-2014, 10:37 AM   #12
extiger's Avatar
2011 30' Classic
Kingwood , Texas
I replaced the hood light bulb with a LED and clear cover (replacing the frosted one). It was a kit from LED4RV. Very happy with the results, more light less heat. My wife liked it so much she said she wanted to replace the over the sink light with something that would serve as more of a task light. Dan from LED4RV suggested a high/low kit and it works great. It has a two way switch so you can either have bright or dim light. She loves it.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
extiger is offline   Reply With Quote
Old 10-23-2014, 05:40 PM   #13
Dan@LED4RV's Avatar
Denton , North Carolina
my guess
My guess is that is the only way the hood range comes from the manufacture of the hood range. I know many folks have put LEDs there with no problems.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 10-23-2014, 06:15 PM   #14
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
LED from Dan. It has the added bonus of being brighter than the incandescent that was there originally.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
LED Conversion: Baraldi Range Hood Lights TinTin Lights - Interior & Exterior 5 07-13-2014 02:38 PM
Hood/hood lights and water heater stopped working!!! Thomas_G Electrical - Systems, Generators, Batteries & Solar 1 06-17-2013 12:49 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
