Old 11-25-2013, 05:21 PM   #1
2015 28' International
Ofallon , Missouri
Which LED for spot reading lights?
Has anyone upgraded their spot reading lights to LED? Did you install the 12 LED or the 9? Curious which one puts out the "right" amount of light.
mpsgolf is offline   Reply With Quote
Old 11-26-2013, 03:57 PM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I did 9 and very bright, now if I want to use it DW sitting across from me asked me to make a shade, best thing is the lack of heat from the LED versus the incandescent.
Old 11-26-2013, 05:42 PM   #3
Remax gal's Avatar
2014 27' FB Eddie Bauer
Lake Placid , Florida
Can you put dimmer switches on these LED lights?
Let the good times roll!! Laura
Remax gal is offline   Reply With Quote
Old 11-26-2013, 07:00 PM   #4
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
I installed 9 LED. I used the warm white. We like them. I also used 9's warm whites in the ceiling. We like them also.
We haven't tried putting a dimmer on them.
The only issue we have with the LED's is interference with the Samsung television when it is on the antenna and the overhead LED's are on. Some digital over the air stations don't come in when the overhead LED's are on. Turn the LED's off and the reception is good. No issues with the LED's and cable.
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2011 Ford F250 Lariat, 6.7 Diesel, 4X4 (Brutus)
TAC FL-55 | WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 12-01-2013, 10:07 AM   #5
Dan@LED4RV's Avatar
Denton , North Carolina
dimmer
Some LEDs can be dimmed with a dimmer but all LEDs have to be dimmed with a PWM (Pulse Width Modulation) Dimmer.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 12-01-2013, 11:57 AM   #6
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
Here is what I used over the bed;
It is a dimmable LED chart light from YachtLights.com
Available is several lengths. I used the 4" which is actually on a swivel, not a gooseneck.
Steamy1 is offline   Reply With Quote
Old 12-01-2013, 12:45 PM   #7
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Is there any solution for the interference caused by some LED's. I had the same issue a few years ago with LED's in the spot reading lamps. I took them out and still have them but can't use with the new trailer ( different base).
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 12-01-2013, 03:22 PM   #8
65CV's Avatar
Western , Massachusetts
We like these Reading Lights. I bought the LED itself and plan to use it in the Porch Light on our '59.
They are the third set of LED lights we tried -- they were the only ones we tried that allowed us to read with the light behind us while boondocking.
65CV is offline   Reply With Quote
Old 12-01-2013, 06:07 PM   #9
Remax gal's Avatar
Thank you all! I sure appreciate it! Laura
