04-19-2008, 07:26 PM
Surprise
Which bulb do I use
After using the seach option and using my service manual I am unable to find which bulb to use for my back up lights. Does anyone know which one goes in a 72 tradewind?
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
04-19-2008, 07:33 PM
, At Large
1156.
04-19-2008, 07:37 PM
Surprise
Thanks O63, I thouht it was 1141 but was quickly proven wrong. The extra bulbs were apparently for interior only.
Jerry C.
WBCCI #13317
AIR #25664
04-19-2008, 07:44 PM
, At Large
You can use the 1141, the main difference is less wattage (the 1141 isn't as bright).
04-19-2008, 07:47 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
How about in the scare light?
HIJACKING FOLLOWS.....
I need to replace the one in my scare light. It looks to have a longer throat for lack of a better term than my other bulbs
04-19-2008, 07:51 PM
Surprise
What is a scare light?
Jerry C.
WBCCI #13317
AIR #25664
04-19-2008, 07:54 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Its the outdoor light by the door. I think that is what I have heard them called
04-19-2008, 07:59 PM
Surprise
All I have is an empty recepticle there so I would like to know too. If I had to guess it would be 1156 also.
Jerry C.
WBCCI #13317
AIR #25664
04-19-2008, 08:00 PM
, At Large
The scare light is the big round light that looks like a backup light off a bus (because it is). The one in our Overlander was a 1034, double filiment. Do you know if yours is a double or single?
If it's a single, don't use the 1156, it will melt the lens.
The same if it's a double, don't use an 1157, for the same reason.
04-19-2008, 08:04 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
You would be guessing wrong if yours is like mine
04-19-2008, 08:05 PM
Surprise
Copy that, I will check the service manual, hopefully it will tell.
Jerry C.
WBCCI #13317
AIR #25664
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Closet light bulb
Tarheel |
5 |
10-23-2020 07:09 AM |
1141 IF bulb Source
Ganglin |
Lights - Interior & Exterior |
1 |
11-21-2007 10:01 PM |
Ceiling bulb replacement?
TennisMan |
2007 Safari SE |
2 |
09-04-2007 08:17 AM |
light bulb
66 Tradewind |
2 |
11-08-2004 05:18 PM |
Dim bulb here - interior
j54mark |
2 |
04-04-2004 08:35 AM |
