Old 04-19-2008, 07:26 PM   #1
azfiredog300's Avatar
Surprise , Arizona
Which bulb do I use
After using the seach option and using my service manual I am unable to find which bulb to use for my back up lights. Does anyone know which one goes in a 72 tradewind?
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 04-19-2008, 07:33 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
1156.
Old 04-19-2008, 07:37 PM   #3
Surprise , Arizona
Thanks O63, I thouht it was 1141 but was quickly proven wrong. The extra bulbs were apparently for interior only.
Jerry C.
WBCCI #13317
AIR #25664
Old 04-19-2008, 07:44 PM   #4
Well Preserved
1993 21' Sovereign
You can use the 1141, the main difference is less wattage (the 1141 isn't as bright).
Old 04-19-2008, 07:47 PM   #5
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
How about in the scare light?
HIJACKING FOLLOWS.....
I need to replace the one in my scare light. It looks to have a longer throat for lack of a better term than my other bulbs
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 04-19-2008, 07:51 PM   #6
Surprise , Arizona
What is a scare light?
Jerry C.
WBCCI #13317
AIR #25664
Old 04-19-2008, 07:54 PM   #7
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Its the outdoor light by the door. I think that is what I have heard them called
Rodney
and the
My Blog
Old 04-19-2008, 07:59 PM   #8
Surprise , Arizona
All I have is an empty recepticle there so I would like to know too. If I had to guess it would be 1156 also.
Jerry C.
WBCCI #13317
AIR #25664
Old 04-19-2008, 08:00 PM   #9
Well Preserved
1993 21' Sovereign
The scare light is the big round light that looks like a backup light off a bus (because it is). The one in our Overlander was a 1034, double filiment. Do you know if yours is a double or single?
If it's a single, don't use the 1156, it will melt the lens.
The same if it's a double, don't use an 1157, for the same reason.
Old 04-19-2008, 08:04 PM   #10
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
You would be guessing wrong if yours is like mine
Rodney
and the
My Blog
Old 04-19-2008, 08:05 PM   #11
Surprise , Arizona
Copy that, I will check the service manual, hopefully it will tell.
Jerry C.
WBCCI #13317
AIR #25664
1141 IF bulb Source Ganglin Lights - Interior & Exterior 1 11-21-2007 10:01 PM
Ceiling bulb replacement? TennisMan 2007 Safari SE 2 09-04-2007 08:17 AM
light bulb 66 Tradewind Electrical - Systems, Generators, Batteries & Solar 2 11-08-2004 05:18 PM
Closet light bulb Tarheel Electrical - Systems, Generators, Batteries & Solar 3 07-26-2004 02:04 PM
Dim bulb here - interior j54mark Electrical - Systems, Generators, Batteries & Solar 2 04-04-2004 08:35 AM
