Old 09-08-2011, 01:10 AM   #1
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
Where to get running light gasket ?
I would like to purchase the paper gasket if possible. I'm replacing all my running lights and would like to do this correctly. I've not see the gasket forsale at Inland or VTS. Please see the pic below for reference. It's at the bottom. Could I make one? What is the material in question? Mine are in bad shape.
MrJ is offline   Reply With Quote
Old 09-08-2011, 02:34 AM   #2
You really don't need a gasket "IF" you seal the hole that the wire goes thru.
That is easily done with Vulkem sealer.
Old 09-08-2011, 04:33 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I seal the hole for both the wire and the screw with a dab of Vulkem/Sikaflex/NP-1. FWIW I also make my own gaskets out of thin EPDM rubber, find a commercial roofing crew putting on that black roll roofing and ask for some scraps. The thinner the better. You might be able to buy bulk gasket material at an auto parts store like NAPA, don't recall having seen any at the local box type auto parts stores.
Aaron
WBCCI #XXXX AIR #2495
Old 09-08-2011, 06:28 AM   #4
Naper's Avatar
Loretto , Ontario
Try a place that sells heavy truck parts
Naper is offline   Reply With Quote
Old 09-08-2011, 06:33 AM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
The only place I've been able to find them is at the Airstream Factory Store. The gaskets come with new lights - not sold alone.
Old 09-08-2011, 06:57 AM   #6
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I cut out pieces from an old tire tube for various purposes, including making gaskets for those lights. Bicycle tire tubes are pretty thin rubber.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Street side brake light not working w/ running lights on NicheVintage Lights - Interior & Exterior 7 08-23-2011 05:54 AM
Running light won't turn off terryd Lights - Interior & Exterior 4 07-20-2011 07:41 PM
Argosy exterior Flood Light Gasket buffaloman Lights - Interior & Exterior 3 07-11-2011 06:41 PM
1988 Running Light Exposed Wire vhariable Lights - Interior & Exterior 2 06-25-2011 08:56 PM
Running light issue solved! Phrunes Lights - Interior & Exterior 0 06-12-2011 09:30 PM
